checking for boost leak
Old Sep 24, 2005 | 07:51 AM
Adam0925's Avatar
This is probably easier than I am thinking but could someone explain how to check for boost leaks? Any help would be great.
Old Sep 24, 2005 | 07:57 AM
kimletrim's Avatar
Registered User
Take of the intake pipe to the turbo. Plug up the turbo housing and introduce air pressure into the turbo. This is normally done with a boost leak test kit. It plugs up the turbo and has a air valve to allow you to introduce air into the system. After that, you listen and look for leaks.
Old Sep 24, 2005 | 08:04 AM
Adam0925's Avatar
any idea where I could get a boost leak test kit?
Old Sep 24, 2005 | 08:10 AM
krafty's Avatar
You make it... Search
Old Sep 24, 2005 | 08:19 AM
Deepseadiver's Avatar
Go to the hardware store and make it. Do a search, Get a PVC end cap, a rubber joint connection (one end fits over the Turbo the other end over PVC end cap) hose clams, and tire inflation valve. put it all together and inflate.
Old Sep 24, 2005 | 08:21 AM
kmcconn9's Avatar
You can make one easy enough, but I bought several different pieces from seperate comanies and it is reliable and looks perfect....
Old Oct 14, 2005 | 11:07 AM
Cajun Power's Avatar
Fighters Garage makes one...
"http://www.fighters-garage .com/evo.html"
Take out the space after garage.
It is about 2/3 of the way down.
