We need Radiator swap
Old Oct 8, 2005 | 11:48 PM
EVO MR FU's Avatar
I need some instruction on swaping a radiator as I damaged on doing mbc install like few other members on here.....There was few threads requesting radiator install but no one helped out!!
Someone with some knowledge help us out with this radiator swap guide.
Pleaseeee
Old Oct 9, 2005 | 02:05 PM
WarmPepsi's Avatar
Pleaseeee
drain it via the plastic plug on the bottom pass side, undo the 2 bolts on the top holding it in... unplug the harness to the fan... undo the hoses... pull it out.
not tough at all.
refill and flush out all the bubbles.
Old Oct 10, 2005 | 02:53 PM
EVO MR FU's Avatar
thanks for the response
how many hoses to unplug?, and how exactly do I refill and flush the bubbles, Do i fill up with 50/50 water/coolant? How much liquid does the radiator hold?
anybody?
Old Oct 10, 2005 | 02:57 PM
an0ther's Avatar
you only have an upper and lower hose and your breather on the top. I think the stock radiator holds 2 jugs. I also messed up mine putting back in fan and bought a koyo. The koyo takes ALOT more than stock. all you need to do is take off cap ON radiator and fill until full. Start car with cap off and wait till it lowers down, keep filling it up for 5-10 min until it wont let you poor anymore. That should be enough, just wait until the car is completely cooled down later and check, your reservoir should be at the full line when car is cold. Remember use half water and half antifreeze, NOT all antifreeze.
Old Oct 10, 2005 | 05:32 PM
EVO MR FU's Avatar
thanks thats good info, may I ask which koyo did you buy? The oem replacement or racing koyo, Im getting a koyo off ebay for 179 oem replacement was wondering if you knew about them and how they compared to the "performance" koyo radiators
EvoDan2004
32
Mar 15, 2016 08:32 PM
Thoe99
May 5, 2015 01:13 PM
answer1o1
Lancer Engine Management / Tuning Forums
Dec 9, 2014 07:47 PM
LancerOZDude
Lancer Troubleshooting
Oct 7, 2014 02:50 PM
Uryelowducky
Pacific Northwest
12
Feb 7, 2013 03:02 PM
