Anyone else run into this????
Hey everyone,
This is my first post on this particular forum, and I have an issue with my Profec B II. I've done a search in this forum on the Profec B and found many different issues / problems with install issues / issues with programming.....etc etc. Anyways, my question(s) to whom may be able to help is....
Has anyone had a problem with the actual controller being inop right out of the package?
I have spent over an hour and a half with Tom from tech support from Greddy, and we went through every possible step from beginning to end. He even had me reset all existing setttings for my 03 EVO and set them again. The problem is that when the controller is on, it will not send a signal to the valve. So therefor my car will only hold 0.918 psi. The valve is not responding in anyway. We checked EVERYTHING!!!!! We ran a jumper wire directly to the valve unit, and it responded. But the controller will not send a signal to make it hold boost setting.
Has anyone else experienced this first hand, or helped someone with the same issue?
Your input / help would be very appreciated, and or a direction to another thread on this subject. Sorry if this may be a repeat thread
Thanks, Tim
Thanks, Tim
fostytou
359
Oct 23, 2025 09:54 AM
Abacus
Feb 10, 2016 10:59 AM
Evo Tengoku
May 23, 2007 06:05 PM
