drain gas for fuel pump install
Old Nov 22, 2005 | 05:58 PM
evo8rcr's Avatar
what is the easiest way to drain the gas in the lines to change the fuel pump? any help would be appreciated thanks in advance
p.s. I did a search and didn't find the answer I was looking for thanks
Old Nov 22, 2005 | 06:00 PM
reeLz's Avatar
I just used a towel to soak up all the fuel that was in the lines. But be quick about it, or the gas is gonna get everywhere.
Old Nov 22, 2005 | 06:03 PM
evo8rcr's Avatar
I was thinking that too but I didn't wanna make a big *** flamable mess if you know what I mean
Old Nov 22, 2005 | 06:05 PM
TEXSRT4's Avatar
make sure your head is NOT below it. an ear or eye full of gas sucks butt, so does gas in the nose and mouth
sleet's Avatar
Remove the line that goes from the tank to the pump, then start the car untill it doesn't start anymore. Eventually all the the fuel will be gone from the lines.
www.evomoto.com
Check that site for the write-up that I used awhile back.
Old Nov 22, 2005 | 06:09 PM
Knightracer's Avatar
www.evomoto.com
What he said but you will still have a little gas come out of the lines so just have a rage there snd you will be fine.
Old Nov 22, 2005 | 06:13 PM
evo8rcr's Avatar
www.evomoto.com
right on I knew there was some way like that to do it I read it in one of the mechanic box but it has been a while thanks a lot
Old Nov 22, 2005 | 06:44 PM
Turbolover's Avatar
1. unplug the wire hareness to the fuel pump
2. turn over the car until it stalls. turn it over 5 more times
3. there should be no gas in lines
p.s. make sure u have under a 1/8 of tank of gas!!!
EvoooB
10
Mar 10, 2017 05:21 AM
Carrier
Lancer Troubleshooting
18
Aug 8, 2007 01:56 PM
dorsalfin
11
Jun 25, 2007 06:06 AM
EVO8LTW
28
Mar 14, 2007 06:13 AM
DynoFlash
Feb 16, 2005 09:27 PM
