HOW TO: Install an EVO 9 CF panel into an EVO 8
Old Feb 28, 2006 | 01:26 PM
dsm_mikey's Avatar
This obviously is not a performance mod for your Evo, however I love the way the Evo 9's dash looks. I really think the CF trim piece improves the overall look of the interior.
TIME: This is a very easy install and only takes about 20-40 minutes to do.
TOOLS: The only tools needed are a Phillips screw driver and a very thin regular screwdriver which is used to pull out the switches from the EVO 8's trim piece
PART #'s : MR654262 (Small trim piece) & MR654261 (Large trim piece w/ vents)
I paid right around $260 total.
Note: The larger piece has the center vents already attached. If you can find a part number w/o these vents, it will certainly be cheaper.
PICTURES: I have pictures of the install, however I'm not sure on how to upload them. I will do this as soon as possible.
1 Start by removing the 2 phillips screws holding the hood above the instrument cluster.
2. Move the hood out of the way.
SMALL TRIM PIECE
3. Remove the Foglight/ACD & Mirror trim piece by pulling gently until it pops loose.
4. Disconnect the switches and remove.
5. Remove the switches and put them into the new CF trim piece.
6. Plug in the switches and replace.
LARGE TRIM PIECE
7. Remove the Climate control knobs by simply pulling them off.
8. Remove the 2 screws which are now visible.
9. Remove the radio trim panel by pulling it off.
10. Remove the 2 screws which are now visible. These hold the large trim piece in place.
11. Gently pull on the trim piece until it comes loose.
12. Unplug the clock and hazard light switch.
13. Switch the clock and the hazard light switches w/ the new CF Trim piece. You will need a very thin screwdriver to release the clips - which hold the switches in place.
14. Replace panel & connect the clock & hazard light.
15. Make sure all of the switches work.
Button everything up and you're done.
-MIKE
Attached Thumbnails HOW TO:  Install an EVO 9 CF panel into an EVO 8-evo-carbon-fiber-panel-install-020.jpg   HOW TO:  Install an EVO 9 CF panel into an EVO 8-evo-carbon-fiber-panel-install-021.jpg
Old Feb 28, 2006 | 01:35 PM
cdavy's Avatar
Registered User
Pictures and cost?
Old Feb 28, 2006 | 02:02 PM
dsm_mikey's Avatar
Originally Posted by cdavy
Pictures and cost?
I am trying to upload the pictures, however they are too large and I cannot upload them. (157KB) If you could let me know how to resize them so they are 100KB I will post them right away.
The pieces cost $260.
MIKE
Old Feb 28, 2006 | 02:05 PM
SilverNine's Avatar
pics?
Old Feb 28, 2006 | 02:28 PM
evo8rcr's Avatar
Originally Posted by SilverNine
pics?
+1
Old Mar 2, 2006 | 07:28 AM
IDRINKV8's Avatar
its not real carbon fiber I hope you know.
Old Mar 2, 2006 | 07:30 AM
EVO8 WHOA's Avatar
for around $100 give or take, you can get the originals overlayed in carbon www.fibercation.com or www.fibercations.com somthing like that
Old Mar 2, 2006 | 07:36 AM
IDRINKV8's Avatar
true true but that stock is not you know
Old Mar 9, 2006 | 07:31 PM
Ruri's Avatar
faux carbon fiber
why not just buy a IX
Old Mar 30, 2006 | 12:05 AM
Andrew LB's Avatar
I was thinking about removing the fake carbon fiber dash insets and sanding them down and having them painted either Graphite Gray like my exterior paint or perhaps "Piano Black".
I think that would look great IMO.
Old Apr 4, 2006 | 10:18 PM
supersupra's Avatar
www.fibercation.com
Has anyone tryied this one, they say they also come in real Carbon Fiber
Old Jun 28, 2006 | 08:06 AM
g3tpwn3d's Avatar
Originally Posted by supersupra
www.fibercation.com
https://www.evolutionm.net/forums/sh...ht=fibercation
Old Jul 26, 2006 | 05:11 PM
EVIL_EV0's Avatar
RICE!!!!!
I'm kidding.....you must have really wanted those inserts.....too pricey for me.
Old Jul 26, 2006 | 05:14 PM
computerguy's Avatar
Originally Posted by Ruri
faux carbon fiber
260 bucks vs 30,000+ ....decisions...
I think it looks ok...nice writeup.
Old Aug 11, 2006 | 09:01 PM
voodoo23's Avatar
bump for fibercation.com. a lot cheaper, pics of the dash on the website.
http://fibercation.com/dash.html
