Need help installing Trailing arm bushing?
Old Apr 10, 2006 | 10:14 PM
BJai02's Avatar
I have a question on how to remove the lower trailing arm from the car.
After I remove the bolt in the red circle the lower trailing arm doesn't want to drop. Do I simply hammer it, or do I need special tool for it?
Thanks!
Attached Thumbnails Need help installing Trailing arm bushing?-trailing_arm_note.jpg
Old Apr 10, 2006 | 10:39 PM
bbbwrx's Avatar
You want to use a pickle fork. Go to Autozone and they will have them. Then you put the fork in there and hammer it.
Really if you do not know how to use it I would recommend taking it to a professional shop because you do not want to tear the boot or wreck the threads on the joint.
Ben
Old Apr 11, 2006 | 04:30 AM
kekek's Avatar
DON'T use a pickle fork! unless you want to destroy the boot that is. Autozone sells a tool which can be used to pop that joint loose. You may have to grind some material off the tool to make it fit properly though, only costs about 10-15 bucks.
Old Apr 11, 2006 | 10:01 AM
BJai02's Avatar
Do you have any description or name of that tool? I will take some pictures and bring to Autozone or Pepboys to see if they know what I am looking for.
Old Apr 11, 2006 | 10:34 AM
kekek's Avatar
Looks just like this:
http://images.google.com/imgres?imgu...D%26safe%3Doff
Old Apr 11, 2006 | 06:54 PM
BJai02's Avatar
thank you for your help!
For those of you who wants to do it yourself, here is a picture of the special OEM tool:
Attached Thumbnails Need help installing Trailing arm bushing?-mb991897-ball-joint-remover.jpg
jid2
Jun 1, 2017 10:30 AM
Galaxshiel
Nov 19, 2016 09:58 AM
Duke1010
Jul 17, 2015 09:30 AM
detnow2009
10
Jul 10, 2015 08:09 PM
Dambay
Jul 23, 2013 06:38 AM
