Fuel Pump Install
Old May 8, 2006 | 08:50 AM
figuerda's Avatar
Fuel Pump Install
Hello all, I'm goign to get a Walbro 255 installed and the tuner place I'm going to is charging me $100 for the pump and $170 to install it, total: $270. Does that seem like a lot of scratch just to install it?
thanx
Old May 8, 2006 | 08:58 AM
smoothmarine187's Avatar
Veteran: Marine Corp
That seems like way to much money for an install. Its a really easy job!
Old May 8, 2006 | 09:01 AM
lil'evil_evo's Avatar
you're getting rapped
Old May 8, 2006 | 09:24 AM
bernardo's Avatar
Not only that, but you're getting raped, too.
Mitsu uses "book time" to bill for the same job, and I think they book it at 1.5 hours, which is about $150. Both places are ripping you off.
Check the "How to" forum here. There's a very easy install guide there. Also check Mach V Motorsports' website, there is a good tutorial on there as well.
It's an easy install if you take your time. Even taking your time, it will only take 45 minutes max.
Old May 9, 2006 | 08:20 AM
figuerda's Avatar
Thanks guys, your all awsome!
Old May 9, 2006 | 10:34 AM
EVOIX4me's Avatar
takes 5 min to install . Evomoto.com has a good install write up
Old May 9, 2006 | 01:37 PM
SR20DE-T's Avatar
It is not hard just take your time and dont be too forceful. If you break on of them barbs you screwed and it takes about 30-1hr.
Old May 9, 2006 | 01:58 PM
what do you mean I'm getting raped.
Old May 9, 2006 | 05:10 PM
bernardo's Avatar
Just busting your ***. Typo in post #3.
Old May 9, 2006 | 05:12 PM
keviin's Avatar
if you can get that damn retainer ring off the first try..for most people the first time taking that ring off takes atleast 15 minutes.
Old May 24, 2006 | 08:49 PM
jmoudry's Avatar
I am going to be installing one of these pumps in a few days and am wondering what is the best way to get the retainer ring off? I am guessing that you have to use a small flat blade screwdriver to pry it off?
Thanks
Old May 24, 2006 | 09:02 PM
Danny23's Avatar
you dont pry it off you tap it i belive counter clockwise
Old May 25, 2006 | 04:55 AM
Talon's Avatar
The price of the pump is pretty good, but $170 to install?!?!?!? What do they charge, $500/ hr.?
Old May 25, 2006 | 05:40 AM
ohio-evo's Avatar
Just use the above write ups. I used these and had no problems. I can now do this job in a mater of 30 min. Just get your tank as empty as possible. that way you have less of a chance of getting any in your car. Good luck man.
Old May 25, 2006 | 06:18 AM
jmoudry's Avatar
Unfortunatly the write up with the instructions on how to remove the sock's retaining ring has a bad link to the picture. If anyone has a picture of this process it would help. Otherwise I will just have to wait until I start the installation to get the whole picture. Thanks for the replies.
