How to create a stealthy interior, black.
Old Sep 2, 2010 | 02:23 PM
  #136
mobilman's Avatar
I'm doing mine right now... looks good so far
Old Oct 28, 2010 | 08:07 AM
  #137
mifesto's Avatar
i did mine roughly 6 - 7 month ago using duplicolor vinyl&fabric paint flat black. painted hvac surround, the long dash piece, shifter base and small switch surround on left side. i didnt use adhesive promoter but i did lightly scuff surfaces with 1000grit paper then used Dupli-Color's Prep Wipe to get as much dirt and hand grease off of it. then hit it w/ one coat of primer then about three coats of vinyl paint. no chipping or cracking. seems to be very durable. love the look!
when the winter hits im sure ill get bored and do the steering wheel next
Old Nov 18, 2010 | 07:02 PM
  #138
ct9asilver's Avatar
To the people saying the paint scratches easily, its because almost every plastic interior part is POLYPROPYLENE, which does not accept 90% of the spray paints available and cannot be dyed after it has been molded, if you look on the back side of your plastic pieces I.E. the pillars, it has a [PP] mark, which means POLYPROPYLENE, I have used KRYLONE FUSION which is formulated for this type of plastic.
On a side note, you can dye the two little plastic sunvisor clips black with RIT color dye, and also the sun visors, the two light housings unfortunately are also made of polypropylene, so again a specialty paint is required.
Polypropylene (Herculon, Olefin) is dyed while still in liquid form, before it is extruded into a fiber. It cannot be dyed at home.
Old Nov 18, 2010 | 07:19 PM
  #139
basm917's Avatar
dude nice jop. il ike it
Old Mar 10, 2012 | 12:01 AM
  #140
mr0072003's Avatar
Bringing Threads from the dead back to life.. Did this today.. Used same paint as in the instructions. I did however sand down both pieces with 800 followed by wet sand with same grit, (MINUS HVAC panel, I just got the DD JDM one) and then washed and then painted... and it looks good. Here are some pics.
Old Mar 11, 2012 | 10:31 PM
  #141
R-motorsports's Avatar
very nice write up. im gonna try this on one of our evos to give it that custom look.
Old Mar 4, 2013 | 08:01 PM
  #142
05wickedevo's Avatar
I also sprayed my shifter surround and ash tray as well as a pillars. Will post pics after I reinstall tomorrow.
Old Mar 17, 2013 | 06:46 PM
  #143
RevMatcher's Avatar
Nice, looking forward to the images..
Old Nov 23, 2013 | 02:19 AM
  #144
KyDSM's Avatar
Doing this tomorrow! Will post pics!
Old Jan 20, 2014 | 08:56 AM
  #145
treager's Avatar
Nice work! will try painting mine!
Old Feb 20, 2014 | 01:28 PM
  #146
Lancerboy89's Avatar
Looks good just waiting for these pics before i go an do mine
Rexpeed
EvoX 'For Sale' Exterior Styling
Oct 14, 2008 10:03 PM
Rexpeed
Evo 'For Sale' Exterior Styling
15
Sep 24, 2008 08:45 PM
Rexpeed
Apr 5, 2007 06:36 AM
Derek888
Aug 10, 2006 09:55 PM
Derek888
Nov 12, 2005 10:22 AM
