How to create a stealthy interior, black.
Old Aug 7, 2007 | 07:48 AM
  #91
Lancelot23's Avatar
Lancer Es, Evo Wannabe
i have a lancer ES. and i have ugly grey interior with woodgrain dash, but i just bought some evo dash peices from someone. i want to paint the stock grey parts black so it makes the evo stuff look better, cuz it doesnt match at all right now. here's a pic.
i want to paint the areas around the radio piece, around the shift knob, the cubby hole, glove box, pillars, change drawer left of steering wheel, etc. but the plastic is not smooth. its like "leather". so i guess i cant sand it? or else i will loose that "leather" look. you think i should go with the Fusion interior plastic paint? black? or glossy black?
also im buying a evo steering wheel. so it will get rid of my big *** grey steering wheel. and then eventually seats, black ceiling, and black carpet. but those are only dreams right now.
HELP ME OUT!
Old Aug 7, 2007 | 08:06 AM
  #92
TomTomTuning's Avatar
Wow, that has to be one of my fav looking cars man... nice work.. real nice work.
I notice that an Evo9 at CBRD had a CF trim, the one around the Clock, i dont know if it was OEM or not but i liked it.
Old Aug 29, 2007 | 07:16 PM
  #93
scotdw6's Avatar
Sleet, I've seen your avatar for years but those pics show just how insane your Evo looks--so badass. did you do your seats, yet? Very interested to see how they come out. The blue sucks.
Old Sep 6, 2007 | 06:33 AM
  #94
dodgecoltracer's Avatar
I love the black and it seems easy enough, even though I'll probably break something. I saw something on here about painting the center part (around the shifter) with a crackle spray paint (similar to the dash/around the ebrake/ect..) I think that'd look real good with the whole blacked out look
Old Sep 12, 2007 | 12:23 AM
  #95
Kirbyryu's Avatar
The black looks really good I am doing mine later on in the day.
Old Sep 18, 2007 | 11:00 AM
  #96
So I'm not very good with the whole car thing, how do I take off the B pillars? It seems like itd be a pain with the seat belt on there... how does it work??
Old Sep 24, 2007 | 09:48 PM
  #97
JohnnyBoy427's Avatar
HELP ME OUT!
I painted my climate control surround on my ES. It did have the bumpy texture but I sanded it down a bit and cleaned it up and never had a problem.
You will have to unbolt the seatbelt off the floor and pull it through. I have done it before to get my carpet out but IDK if it is safe so I dont take responsibility if your seatbelt comes loose in a crash.
Old Sep 25, 2007 | 07:09 AM
  #98
asdfasdf128's Avatar
its amazing what you did, it pretty much looks stock. Good job!
Old Sep 29, 2007 | 04:00 PM
  #99
joon82's Avatar
looks good. But everytime i spray paint, i get stupid drips and errors. I messed up one radio console so had to buy new one.
Old Oct 2, 2007 | 05:10 PM
  #100
MSFIT's Avatar
thats awesome I wanna do this
Old Oct 4, 2007 | 11:11 AM
  #101
Kirbyryu's Avatar
Originally Posted by sleet
Well I grew very bored with my interior, the fact that some of the trim peices didn't match. The majority of the interior is black, but yet some sections of the interior were a grey color. So I decided to paint them black and match them with the rest of the interior, enjoy.
Tools you'll need:
  • Exacto knife
  • Painters tape
  • Screw driver(Philips and flat)
  • Dupli-Color Vinyl & Fabric paint
  • Ventaliated area to paint/dry
  • Patience
1. First your going to have to remove the interior peices you wish to paint, I decided I wanted to paint my A-pillars, the peice around the foglight, the peice around the radio, and lastly the long peice that holds the clock. If you know how to already remove these peices then just skip this, if not then continue reading.
Remove A-pillars:
To do this you can use a flat head screw driver, simply place the screw driver at the top of the pillar and pull it back enough to get a finger behind it. Then slowly pull on the pillar while sliding down towards the windsheild, there are 2-3 clips holding it in. Don't be afriad to pull a bit, but remember this isn't the world strongest man contest.
Remove the peice around the foglight:
To remove this peice you are going to have to remove the plastic outline around the cluster. You will see two screws at the top, they required a philips to remove. Once you remove those that peice you will have access to removing the peice around the foglight. Simply pull the side, again don't be afriad to pull but don't go crazy with it. Once you've pulled the peice from the clips, unplus the harness connecting to the sidemirrors controller and the foglight switch. To remove the button/switch from the interior peice, you will need a small flat head. On top of the switch/button you will see a slight tab that is holding the peice in, slide the flathead in there to lift it enough to pull the button/switch out.
Remove peice around the radio:
The easiest one to remove, simply pull on the three AC knobs, they'll come right off. Behind the outside two knobs you'll see a screw, use a philips screwdriver and remove them. Now your going to have to use the holes from where the knobs were to pull the peice out. If this is the first time removing this peice you might have to tug a good bit, again don't go crazy.
Remove peice around clock:
Last but not least, after you've taken off the peice covering the radio you'll see two screws holding this peice on. Remove them with a philips screw driver. Now your going to have to pull from the left side and move to the right, go slow. There are a good amount of clips on this one so don't be afriad when you here a bunch of pops. Also don't rip it right off because the clock and hazard button are connected.
By now if you've followed everything as said your car should look somthing like this
2. Now that you've got all the peices out of the car you'll need to wash them, make sure the surface of the plastic is clean/dry so the paint will stick. I used some paper towels with a bit of soap on them, I ran the paper towel over all the peices and then dried them with a towel.
3. Time for the best part, painting. So grab your paint:
And find a nice spot you'll be able to paint in, I chose my driveway and I laid down some paper with a box, like so:
First we'll start off with the A-pillars, I applied 3 coats and let each coat dry for about 5-10 minutes before spraying the next one. The final result should look somthing like this:
Next we'll paint the peice around the radio, this is where you're going to need the exacto knife and painters tape. Since this peice has the climate controls on it, you'll need to mask them off so you don't paint of them. Take the painters tape and apply a peice over the circle, use your nail and press down to outline the circle of the climate control. Use the exacto knife to cutout the circle and leave it there to mask. When your done it should look somthing like this:
Now that you've got that peice masked off, we'll move onto the next peice, the area around the clock. On this one you need to turn the peice over and you'll see that the AC vents/clock are all one peice and screwed on. Simply get a philips head and remove the screws:
Now it's time to paint the rest of the peices. For these peices I only did 2 coats, I didn't feel the need for the third and they came out very good IMO, here they are:
Before:
After:
That's pretty much it for the painting section, you can clear the peices if you want them to shine a bit. Although I didn't want that because none of the other peices have gloss. I let the peices all dry out for a few hours before putting them back into the car.
Now once you've put them back into the car it should look somthing like this:
I hope this writeup helps, if you've got any further questions please let me know. I'd be more than happy to help
I did my A, B, and C pillars and even done the hazard button
Old Oct 8, 2007 | 05:38 PM
  #102
sgand's Avatar
Awwwww man, now I want to do this.
I did my last car, and here I am 4 years later and it looks like complete ****. Good thing I sold it.
I just don't want to run into the same problems down the road with cracking, chipping, peeling, yada yada.
Old Oct 23, 2007 | 08:59 PM
  #103
sleet's Avatar
Wow, I haven't been on here in FOREVER. I've been wayy too busy but everything is still holding up and I haven't had any problems with my paint at all.
Old Jan 12, 2008 | 08:05 AM
  #104
jdmrally's Avatar
hmm, did you just use the vinyl and fabric paint? I tried that too and the first time anyone reached for something they scratched it. So I went back and started cleaning it with acetone, Then I went back, sanded it down w/400 grit then 1500grit, applied an adhesion spray, 4 coats of Black Vinyl and Fabric Spray let dry then 4 coats of clear let that cure also, then before we installed it we wet sanded with 2000grit. It took us a little more than a week, but it last so much longer, you can scrape up against it without it causing damage. I even dropped a piece on the concrete and it didn't do anything :-)
Old Jan 21, 2008 | 07:04 AM
  #105
Guz Man's Avatar
very nice.. gonna do only the Hvac part this weekend... thanks for the inspiration..
