Best way to remove paint from wheels??
Old Sep 1, 2006 | 09:06 AM
EVIL_EVO_VIII's Avatar
I wonder if the paint thinner would do anything to the tires?
Old Sep 1, 2006 | 09:17 AM
DRFTKNGG's Avatar
Originally Posted by feautoevo
oh yess the aircraft paint stripper, i did it on my black hood grille, just sprayed it on, let it soak in and the paint bubbled up, then just sprayed it off with a power washer, just be careful that stripper is no joke, I wouldn't get it anywhere but the rims
Also says do not get on rubber! Nasty stuff on rubber. Makes it swell like a blister.
Old Sep 1, 2006 | 09:18 AM
machron1's Avatar
I would just take the tires off then sand/bead blast it down to bare metal and get them powder coated. If you want to do a good job you won't leave the tires on.
Old Sep 1, 2006 | 09:22 AM
ziggy_juju's Avatar
I do not think the thinner would tear up the tires to terribly bad, but just in case why dont you tape them off before you apply thinner, at the very least a couple of layers of 2 inch tape around them, if it will not stick, wipe your tires down with a light coat of thinner to remove any tire dressing etc etc. IF you use the B12 chem tool, aka aircraft stripper, MAKE SURE you protect the tires in some way cause that stuff if gnarly. Also what kind of paint did you use? Rattle can??? If so laquer thinner will do the trick no problem. But if you want the safest way, just sand it off. Keep in mind that some wheels( I am not sure if the stock enkies come this way or not) have a clear coat on the factory finish, so you will most likely need to put some sort of refinish on them.
Josh
Old Sep 1, 2006 | 09:26 AM
DRFTKNGG's Avatar
Thats what I said....I think he will do this, remember Miguel that guy Frank, he said he would hook us up on the powdercoat, $50.00 a wheel.
DannyF6
08+ Lancer Show / Shine
Jun 29, 2010 09:59 PM
4myX
Mar 19, 2008 06:45 PM
evoixpr
Jul 26, 2007 12:12 PM
5230EVO
Sep 28, 2006 07:24 PM
Eva01
10
Jul 9, 2004 07:09 AM
