Fuel Pump Install Problem!
Old Oct 17, 2006 | 04:59 AM
topnotch_EVO's Avatar
I installed the 255 pump and my car would not start. I went back and then reinstalled the stock pump, and still would not start. I did accidently take off the ground connection even though I did not need to, might that have anything to do with it?
I checked all fuses and all are good.
Please give me any suggestions you have!
Old Oct 17, 2006 | 05:06 AM
MIevo8MR's Avatar
Did you put the ground connection back or is it still off?
Old Oct 17, 2006 | 05:09 AM
Lancematic's Avatar
I am assuming that when your reinstalled the stock pump it worked? If that is the case, then something may be wrong with the 255. It installs the same exact way as stock.
One thing that you may not have accomidated for is that the pump needs to prime. How long did you try to start it for?
Old Oct 17, 2006 | 05:12 AM
deffro's Avatar
Yeah. You have to turn ot over for a few seconds before it will crank
Old Oct 17, 2006 | 05:15 AM
I did connect the ground back up.
It did not work when i reinstalled the stock pump.
I believe that it has something to do with the ground. Correct me if i'm wrong but There is a metal tab inside the ground connection, is that supposed to go inside the round end on the bottom of the ground clip.
And is there an O ring that is supposed to go there as well?
The fuel pump, neither stock or the 255, is getting power. I can't hear either of them winding when i connect them.
Old Oct 17, 2006 | 07:12 AM
troe666's Avatar
have you blown your fuel pump fuse?
not sure if its in-cabin or under engine bay in the Evo, but its possible now.
so long as youre sure all wiring is correct that is,
Trav
Old Oct 17, 2006 | 07:20 AM
lexat20's Avatar
grab a fluke and test your continuity on the fuel pump fuse and the relay under the hood.
Old Oct 17, 2006 | 02:02 PM
thanks guys i fixed it though and i'm not really sure how. I took it out a couple more times and messed with that ground plug and switched the relay's around to see if it was that. I plugged it in and tried starting it and it worked.
Old Oct 17, 2006 | 02:20 PM
kreionic's Avatar
Little tiny o ring. Mine did the same.
Bloomie
10
Jan 28, 2024 09:31 AM
Joshs EVO
Aug 29, 2013 07:24 AM
sourtowel
Apr 22, 2013 04:24 PM
BCOZEVO
Mar 3, 2008 08:09 AM
ace_2822
16
Sep 8, 2006 11:56 PM
