Routing Line for Meth
Old Oct 22, 2006 | 05:26 PM
saiyanzzrage's Avatar
hey guys, I need to run my meth line from the trunk (smc kit) to the engine bay, and to my uicp where the pipe is tapped for the meth (at the throttle body)
I have the line for the meth through the fender so far, but I could have sworn there was a hole in the fender in the engine bay by the master cylinder somewhere, yet I cant find it...please tell me where it is so I can finish up my meth install tonight..thanks in advance!
i dont want to drill my firewall....
Old Oct 22, 2006 | 05:34 PM
bump, i want to get this done tonight! thanks
Old Oct 22, 2006 | 05:54 PM
ttt
Old Oct 22, 2006 | 07:30 PM
can anyone help me?
Old Oct 22, 2006 | 07:39 PM
evolsk8r's Avatar
It sounds to me like you're going thru the inside of the car? I routed mine underneath the car, following the fuel lines all the way to the front of the car, using zip ties to hold it in place. Then just go up thru your engine bay to your upper pipe. I'm pretty sure this is how most people install it. Nolimit motorsports did a how to, and it also shows this method.
Old Oct 23, 2006 | 02:29 AM
DanJ's Avatar
The only grommet that I know of in the firewall is behind the glovebox to the right. Or if your in the engine bay it's behind the passanger side strut tower. I believe the MR's have their boost gauge line going through there already.
Old Oct 23, 2006 | 07:03 AM
yes, you are correct, i am running the line for the meth from the trunk, inside the car under the door sills, then into the engine bay through the drivers side fender (the line comes out from the fender right by the driver headlight)
the under car method seems perfect, but one more question, how do you get the line from the trunk where the pump is to the underside of the car? do you drill a hole?
Old Oct 23, 2006 | 07:14 AM
yeah, that one i know about, i have my hks evc and defi boost gauge lines running through there, but that wont really help, its on the complete other side of the car
Old Oct 23, 2006 | 08:25 AM
evolsk8r's Avatar
There is a drain plug inside of the driverside rear fender. Just open the compartment on the opposite side of the windshield washer fluid and feel for it. That will put you underneath the car.
Old Oct 23, 2006 | 08:36 AM
thanks
Old Oct 24, 2006 | 12:46 PM
I actually solved my problem by calling SMC directly..they are sending me a 4 foot extension braided line so i can reach the throttle body from where i have the line entering the engine bay
Big thumbs up to SMC, they have awesome service, I needed a 15gph nozzle before my tune and they sent it out to me free of charge
nsheasley
Dec 7, 2015 07:11 AM
pcamara17
53
Jun 14, 2010 08:46 AM
evogottago
16
Jul 11, 2008 12:18 PM
Pure Playaer
Jan 3, 2008 09:17 PM
1mbrews8
Nov 17, 2007 02:54 PM
