EVO 9 MR HID ballast/ bulb install help..
Old Nov 4, 2006 | 12:23 PM
jrod0187's Avatar
A quick overview of what i am trying to accomplish
I have an EVO 9 GSR...I bought EVO9 MR HID Bulbs and Ballasts
The bumper is off and the driverside headlamp is out
This is what I have
I am no expert on HID's/ lights and have been searching on here for the past Hour with little results
Problems:
#1 I am at a point where, as u can tell by the pics, the bulb connector doesnt connect into the lamp housing on the headlight (low beam).
#2 I have no idea where to plug the power to the ballast at...since the connector doesnt fit on any power connector coming from the wiring harness in the engine bay.
#3 Theres a connector on the ballast itself which looks to be a ground wire but also looks to be a spot to plug some thing else in
I need some help and would appericate any thoughts/ experience others can provide for me
Thanx in advance
-Jarrod
Old Nov 4, 2006 | 12:28 PM
evo gerg's Avatar
u need the HID projector housings also besides bulbs and ballast. the regular gsr headlights only fit the 9006 bulb, not the d2s hid bulb.
Old Nov 4, 2006 | 12:54 PM
jrod0187's Avatar
So i need to get the whole MR headlamp or just the projector housing? What about the power connector from the ballast to the car? is there a certain connector I need for that as well
Thank you, deff. helped
-Jarrod
Old Nov 4, 2006 | 01:56 PM
boostfedevo's Avatar
I just did this conversion 2 weeks ago, You need HID headlights to start with. I wired up Relays and extra 20amp fuses to protect the stock wiring harness also. Your going to have to wire the 9006 contector into the new HID Harness on the headlight itself This tread should help you out alot, He didnt use a relay like HID planet explainsed to use but it still helps you out alot. If you need a relay i have one extra i could sell you and draw up the diagram so you know were to connect everything... Also Soldering is a must i would say to. PM me if u have any question i would love to help.
https://www.evolutionm.net/forums/sh...em+hid+running
Old Nov 4, 2006 | 06:51 PM
jrod0187's Avatar
thanx for the info...think I'm all set and figued a few things out
Old Nov 6, 2006 | 07:02 AM
jrod0187's Avatar
Would i be better off with a retro kit? What does the OEM HID kit offer opposed to a retro kit....?
Old Nov 10, 2006 | 02:12 PM
UCB's Avatar
UCB
If you want to retrofit projectors in, then you need to open the housings up and custom mount HID projectors
The OEM HID lights already have the HID projectors
They both will have similar output, well depending on which projectors you use (if you retrofit)
Old Nov 10, 2006 | 04:03 PM
jrod0187's Avatar
thanx....buying a set of MR hids off of Evodave already
Old Nov 10, 2006 | 04:15 PM
UCB's Avatar
UCB
yeah thats really the easiest way to go. The only think you need is a wiring harness to power those ballasts
krispytapa
Jul 15, 2015 11:30 AM
jrod0187
May 18, 2015 10:47 AM
jrod0187
For Sale - Part Outs
64
Sep 11, 2013 10:11 AM
RPWIII
Dec 19, 2011 11:38 AM
MR
Dec 18, 2005 08:30 PM
