How To Relocate The Sports Meter Kit/Replace Factory Stereo
Old Sep 8, 2003 | 07:23 AM
webguy330i's Avatar
Just out of curiosity (great details btw, thx!) is that a 1.5din HU?
Old Sep 10, 2003 | 04:13 AM
freedom's Avatar
Temp Sensor & Gauge Colors Don't Match
What tool do you use with a torque wrench for the Mitsubishi oil temp sensor given that the wire shown below cannot be removed from the sensor?
Also my gauge package has blue back lighting for the volt and oil gauges, while green back lighting for the boost gauge. Is this normal?
Old Sep 11, 2003 | 06:18 PM
tom@kartboy's Avatar
Re: Temp Sensor & Gauge Colors Don't Match
i would use a brakeline wrench to install/remove that sensor. you can usually guess close enough what the torque is.
tom@kartboy.com
Old Sep 12, 2003 | 09:05 PM
freedom's Avatar
Re: Re: Temp Sensor & Gauge Colors Don't Match
tom@kartboy.com
Slotted a 19mm deep 6pt socket tonight. The result is similar to an 02 socket. No problem getting the proper torque.
A comment on the gauge back lighting. The lighting is on full and cannot be controlled by the dimmer control on the dash. This is because the dimmer assumes that the lighting is referenced to +12V (battery). The dimmer controls the ground connection.
The sport gauge kit on the other hand has one side of the backlight bulb connected to the ground for the meter. The other side of the bulb is the gauge's light connection. Thus the gauge is not compatible with the Evo's means of adjusting brightness. (Just hooking up the meter to the dimmer output causes the gauges to be bright when the dash is dim, etc.)
What Mitsubishi did was to connect the gauge backlight power to the car's tail light power! Thus when ever the tail lights are on, so are your gauges. At full brightness.
There doesn't seem to be an obvious means of making the gauges dim with the balance of the dash, unless one modifies the gauge internals.
Old Sep 23, 2003 | 06:55 PM
RedEvoInKy's Avatar
Excellent post! I managed to complete the swap in about 20 minutes with the help of your writeup! Thank you.
A couple of side notes...... I had to go to my local AutoZone and buy a vacuum hose (about 6 inches) because my dealer didn't leave enough vacuum hose length for the move. It was actually pretty short.
Also, be sure to cover your center console with a rag or something to ensure you don't scratch it..... The metal edges on the gauge cluster are pretty sharp....
Old Oct 24, 2003 | 08:42 AM
Peazoo's Avatar
Is the backlighting of the gauges green and blue? Also are they 45mm gauges. I was thinking of just getting the cubby replacement, din gauge holder and omroni gauges that match the i/p cluster red on black.
Old Oct 24, 2003 | 12:56 PM
freedom's Avatar
Both and in reality they all look white given that they are on full and cannot be dimmed based upon the wiring in the car.
perversity
87
Jul 5, 2017 06:54 AM
07EvoIX
Nov 14, 2015 11:18 PM
lancealott
Apr 6, 2010 08:54 PM
ricardon
West Region
13
May 19, 2004 06:29 PM
perversity
May 23, 2003 02:09 PM
