How to install a nipple on an Aftermarket LICP. Fixes Low boost flutter of BOV
I had my motor built for road course recently and my trusty MR BOV was replaced with a GReddy unit. After trying every adjustment and still experiencing flutter, I am going to read this thread a few times and make decision which path I take next (after confirming hoses are absolutely connected properly).
Thanks for the insight
Reviving this one...there is no vaccum lines going to this nipple on the licp, right?? Or is there? Im confused, I never saw anyone mention anything about connecting a line to that nipple.
In the stock outlet pipe on the turbo that connects to the LICP there is a nipple. LICP's that replace this stock outlet pipe usually omit this "nipple" which is used a boost/vac source.
So if I want to avoid boost flutter, I would run the vac line from the intake manifold to the boost controller, and I would install a nipple on the licp and run the vac line for my bov to the ic pipe so that its separated from the mbc vac line?
I'm also confused.My vacuum line comes off the turbo outlet pipe and looks like it's going to my electronic boost control solenoid.Would i still get boost flutter with this set-up?
fostytou
359
Oct 23, 2025 09:54 AM
webguy330i
Sep 7, 2005 12:27 AM
