BOOST/AIR FUEL/OIL TEMP quick question
Old Feb 7, 2007 | 11:37 PM
80210's Avatar
Do you have to splice any of the above into your ECU or do all go directly to engine? Thanks...
Old Feb 7, 2007 | 11:45 PM
badhabit90's Avatar
no.
Old Feb 8, 2007 | 03:04 AM
GraphanaticIXSE's Avatar
You will have to run independant sensors for the gauges. The air/fuel gauge, in perticular, will need to be ran through the firewall. If you have the low band sensor, connecting it to the ECU will give you constant fluctuations on the gauge and the only 'accurate' readings you will get would be when you down shifted or at open throttle. The boost gauge can't measure boost without the tubing going to the turbo. And the oil pressure is the same... Good luck and have fun
Old Feb 8, 2007 | 03:10 PM
80210's Avatar
Thanks everyone!
flyinmonkey101
30
Dec 27, 2016 08:46 PM
plokivos
Southeast Region
41
Jan 3, 2005 10:39 AM
noriceoz
Lancer Engine Tech
14
Nov 7, 2004 05:43 PM
