Detailed Defi-Link Boost & Oil Pressure / Temp Directions
Old Feb 18, 2007 | 04:13 PM
Sakamara's Avatar
I now have *detailed* and complete directions for defi-link boost and oil pressure / temp install posted on my web site with plenty of pics. I have additional directions for the glovebox removal and a-pillars as you may need to do these also.
http://www.evolution-8.com/howto.php
If anyone has questions or pictures that you would like to see that I do not already have posted, let me know and I will see what I can do.
Old Mar 11, 2007 | 11:45 PM
Whoop_ass's Avatar
hey checked the link on your website
thanks for all the great info
good job nice pics detailed write up
thanks
Old Mar 19, 2007 | 05:44 PM
80210's Avatar
EXCELLENT SITE! By far this and evomoto.com have my favorite install sections, great information with large and clear pictures. Awsome!
Old Apr 15, 2008 | 04:57 PM
crctslt's Avatar
I have a problem in that my oil pressure warning buzzer runs constantly if I have the car off and want to listen to the radio. Anyone have a fix for this?
Old Apr 22, 2008 | 09:48 AM
GroundHog's Avatar
great how-to's. thanks!
Old Aug 14, 2008 | 11:55 AM
dunk186's Avatar
thanks
great write up helped big time
Old Aug 18, 2008 | 08:40 AM
EVO8speed's Avatar
Please take note that Defi Gagues that are non-imperial (metric or SI) must use BSPT Adaptors, as this is the correct thread pitch. NPT Adaptors are for Imperial Defi Gagues only. Lowes sells BSPT Adaptors in the plumbing sections, I'll post the part numbers later. While 42 designs sells the adaptors, the Lowes pluming hardware actually fits more flush and leaves a more clearance between the sensors and the axle. I'll take some pictures and post those too.
Old Sep 18, 2008 | 12:07 PM
jlee's Avatar
My didn't come with the wire taps for splice into the radio harness.
can anybody tell me where i can get some of those. thanks in advance.
Old Nov 19, 2008 | 09:50 PM
compscibOi's Avatar
You can get some from Autozone.
Old Nov 19, 2008 | 09:54 PM
compscibOi's Avatar
I figured I would use this thread and hope someone who has Defi BF gauges chimes in.
I have the Defi BF gauges; boost, water temp and oil pressure. I spliced into the radio harness using the following method:
Red Red w/ Black Stipe Constant Volt.
Orange Blue w/ Yellow Stripe Ignition On
White Green w/ White Strip Illumination
Black Bolt near radio Ground
When the key is in the "ON" position the lights on the Defi control unit come on. When I start the car or turn on the running lights, I only get lights on the control unit and the gauges do not light up or turn on.
I have the gauges daisy chaned and then hooked up to port 1. I tried port 2 for the gauges as well and nothing for the guages.
Is the something I am missing? I want to make sure the unit turns on and I have power before I start hookin up the sensors.
I already have the water temp sensor on the upper radiator filler neck, just not hooked up.
Anyone have any insight?
Old Nov 20, 2008 | 07:48 AM
compscibOi's Avatar
Anyone?
I don't have any of the sensors plugged into the control unit, the gauges will at least power on right or since I have three gauges, will I have to plug in all 3 before they at least power on?
Old Nov 29, 2008 | 01:03 PM
compscibOi's Avatar
FYI they are now working.
Old Dec 18, 2008 | 02:12 PM
SunKren's Avatar
WOW. Great site.
Old Mar 12, 2009 | 08:18 AM
Inprogress's Avatar
Is there any other method to tap a illumination source besides the radio harness?
Old Jun 14, 2009 | 03:27 AM
demodeakin's Avatar
Awesome Write up and Pics.... I can wait to install my DEFIs as soon as my 42 Draft Design Adapters come in. I relocated the Radio early and everyone looks and wonders what happened to my Dash...hahaha
Which Pillar Pod is that? I have the JSCSpeed Panel for the Center mount but I kinda like the look for the Pillar Gauges.
Deak
