How to Install an AutoDimming Mirror
Probably could have. I wasn't sure if it was easy to pass the wires through to the dome spot or if a fuse would fit up there (someone should check on this), but I was installing a tap for my passport 8500 x50 anyway. Thats why I went all the way to the fuse box.
btw, nice write-up. definitely will use this when i do my install.
at the risk of sounding like a complete noob, how do you 'add-a-fuse'? I want to do the fuse box hook up for a radar detector (V1) and I really REALLY don't like the idea of tapping the cig lighter. Fuse box seems way easier. Between tapping a switched wire and adding a new fuse all together, it seems like adding a new fuse would be a more professional install. I'm a bit OCD.
Btw, excellent write up, great pics, wonderful effort. I really appreciate it
Add a fuse is an actual product. It is the same general shape as a standard fuse, but is really a fuse holder. It works in that it allows you (if properly aligned) to add a "power line out" from an already existing fuse location without tapping any wires.
