HOW TO: modify your stock "lancer" gauge to accept useful gauges
Old Nov 13, 2008 | 09:41 AM
hattackk's Avatar
awesome mod
Old May 7, 2009 | 04:48 PM
kaj's Avatar
kaj
i believe my AEM unit will disassemble and fit in that spot. hm....
Old Jun 19, 2009 | 05:36 AM
hayden81's Avatar
VEI makes 38mm gauges that should fit I'm not real sure what would be good there maybe oil pressure off the same tap as your turbo
Old Jun 24, 2009 | 02:18 PM
project95gsx's Avatar
Did you get a chance to install the AEM into the dash? Did it work? It'd be rad if it would.
Thanks SophieSleeps for the awesome write-up.
Old Sep 19, 2009 | 12:40 PM
Efini93's Avatar
Is it possible to use a standard 52mm gauge such as an innovate wideband? Or is it too big?
Old Nov 9, 2009 | 09:34 AM
REV.olution's Avatar
Looks interesting props
Old Dec 24, 2009 | 09:55 AM
clifhanger87's Avatar
has anybody found a 38mm boost gauge?
Old Dec 24, 2009 | 10:18 AM
Aman's Avatar
45mm is the lowest. unless u want to pull one out of the old Porsche trubo cluster.
Old Dec 24, 2009 | 11:39 AM
what's that gauge you have in your lancer spot?
Old Dec 24, 2009 | 11:41 AM
Aman's Avatar
omori...
Old Dec 24, 2009 | 12:20 PM
boost? what size?
Old Dec 24, 2009 | 01:09 PM
Aman's Avatar
30 45mm
Old Dec 24, 2009 | 02:26 PM
thanks dude. looks like it fits in the dash. right on.
Old Dec 24, 2009 | 03:27 PM
Aman's Avatar
yeap. but sticks out in a backa bit.. u need to seal the cluster using silicone cause the plastic tab will be hard to get in.. or they will pop out.
Old May 11, 2010 | 07:08 AM
syclone50's Avatar
sorry to dig up an old thread but what WB gauge was used in this mod
