HOW TO: modify your stock "lancer" gauge to accept useful gauges
To do this I had to pull the AEM gauge appart, and desolder the LED Digit Segments and create an extension harness. I then took the 3 segments super glued them together, and epoxyed them to the gauge cluster.
if you are not good a soldering, then I would not recommend this. It took quite some time to do. desoldering is a pain unless you have the right stuff.
To take the gauge appart, I just had to cut the back off with a dremel, and then just continue cutting the case off until the guts finally came out. After I desoldered the LED Number Segments, I then ran some 22 or 30ga wire from the circut board to the new location of the digits. You have to wrap all of the wire very well because the small gauge wire is very fragile and will break easy. I used a lot of epoxy to hold everything togeter.
Next time I take my gauge cluster out of the car I will snap some pics.
Looks Great! im planning on doing this, do you happen to know what size the bulbs are for the gauge, tried a nother thread but all the links were broken. kind of wanting to do everything at once
antics22
Evo X How Tos / Installations
201
Jan 5, 2022 06:24 PM
Aby@MIL.SPEC
Mar 9, 2021 11:41 AM
trinydex
141
May 18, 2018 09:34 AM
antics22
267
Dec 6, 2016 08:40 AM
500whp.com
87
May 31, 2016 01:30 PM
