Need help removing front Brembo calipers!
Old Apr 20, 2007 | 02:40 PM
hotrod2448's Avatar
I'm pretty sure we understand. I just think you don't. You keep talking about the front and the rear sections of the caliper. If your doing it right there are no "sections" of the caliper. It all remains one piece.
You take out the two bolts that hold the entire caliper assembly to the spindle and lift the caliper up off the rotor. The bolts are on the spring side of hub assembly.
What you have done is taken the one piece caliper apart. This pic should help.
I don't think there are any internal fluid passages that go from one half to the other but, you should definitely let someone who knows what they are doing put that back together, bleed the brakes and thoroughly check for leaks afterwards.
Old Apr 21, 2007 | 06:31 AM
jrod0187's Avatar
Yea.....ok thanx for the pic... i see what ur talking about now. I did one side that way and did the other side the other way just to get a feel.
Thanx for everyones input
Old Apr 21, 2007 | 09:35 AM
nofear's Avatar
Originally Posted by jrod0187
I dont think you guys understand what I am talking about. Pics will help better
Why dont you post some pics of what you've done and we can help you out from there.
Old Apr 21, 2007 | 11:36 AM
hotrod2448's Avatar
Welcome.
I seriously can't stress enough the importance of getting the system bled properly and having the caliper correctly reassembled and torqued. Brakes are not a good system to "think" you've got back together right.
Subi.convert
For Sale - Wheels / Tires
Jun 26, 2011 11:21 AM
shannon-evo
Apr 10, 2011 05:01 AM
stageup
Jul 16, 2010 05:48 AM
os2
May 4, 2010 09:41 AM
frijolee
Nov 10, 2007 02:02 AM
