does the oil filter really madder?
Old Apr 28, 2007 | 09:37 PM
Kevin Knight's Avatar
whet to autozone today and got some oil and a new filter. got mobil 1 5w30 motor oil and a mobil 1 oil filter. alot of people ive read get the mitsubishi oil filter from the dealer. does it really madder at all?
Old Apr 28, 2007 | 09:45 PM
idriveanevo's Avatar
it does maTTer. ive seen a subarus turbo seize up because of a cheap oil filter
Old Apr 28, 2007 | 10:02 PM
is a mobil 1 oil filter cheap? i payed $12 for it.
Old Apr 28, 2007 | 10:03 PM
its fine
Old Apr 28, 2007 | 10:04 PM
evo542's Avatar
don't put the fram ones in they're JUNK, worst filter you can buy
Old Apr 28, 2007 | 10:06 PM
what are you talking about FRAM filters are amazing!!!!!!!! apparentley you havent seen the commercials. dont slam it FRAM it!!!!! they cant be junk with a commercial like that!!!! lol
Old Apr 28, 2007 | 10:08 PM
are u useing 10w30 or 5w30
56Hotrod's Avatar
I have no experience with Mobil 1 filters. But I agree, I'll never put a Fram in any car I own again. My last car, a 98 AWD TSi, developed a serious case of phantom knock. In researching, I read a lot of bad stuff about the Fram's. I decided to do a test.
I changed my oil, put in a Fram filter, went out and datalogged a run. Definitely phantom knock as timing was being pulled.
I went back, changed the oil again, and installed an OEM filter from the dealer and repeated the run. No more phantom knock. Since then, I've only used filters from the dealer.
Hope this helps.
Old Apr 28, 2007 | 10:16 PM
91TB78's Avatar
Stick with the OEM filter. I paid $4.75 today for mine. I think list is $5.50 or so. They're inexpensive and seem to work the best.
Old Apr 28, 2007 | 10:31 PM
mrich82's Avatar
Some dealers even give a discount if you buy more than 3 filters. I paid around $5 for mine the other day with a new drain plug washer.
Old Apr 28, 2007 | 11:03 PM
gsrboi80's Avatar
Do not use the orange FRAM. However the FRAM X2 is actually one of the best filters you can buy
Old Apr 29, 2007 | 01:09 AM
03hurley's Avatar
what about k&n??? anyone have anything good/bad to say about them
Old Apr 29, 2007 | 03:58 AM
andyktlee's Avatar
Pocket Mo
There is absolutely no need to buy a filter that's over $6. There are good filters for relatively few $: Purolator PureOne, WIX, STP, etc. The K&N air filters aren't even very good at filtering. You're paying for the K&N name and there's no way I would be happy with K&N's level of filtration when it comes to an oil filter.
I personally use WIX filters on all cars I regularly change the oil on and I get them for roughly $5 after tax.
Old May 1, 2007 | 08:23 PM
PlanoEvo's Avatar
The Mobil 1 filter is a superior filter and I have used many different filters over the years on my work trucks that have logged over 500,000 miles and the M1 filter keeps the oil cleaner longer and reduces oil comsumption versus any Fram,valvoline,Motorcraft or any $5 or less filter. Think about if the Dealer sells it for $5 it is probably no more than a $3 filter....Now that being said is the dealer filter a bad filter no but regular oil isn't either but Mitsu puts synthetic oil in at the factory. So why use a plain old filter when better filters are out there..
Old May 1, 2007 | 08:29 PM
Huy's Evo's Avatar
i get a mitsubishi filter for 4.50 with washer with my discount from work.
