Install: Perrin Short Shifter (pics)
Old Jun 28, 2003 | 03:50 PM
wojo's Avatar
First things first: This thing is a ***** to install. It took me half a day to do this, but that’s mostly because I wasn’t prepared for some of the “surprises” along the way. I gotta say though, once you go through the pain with the installation, it’s worth it. The shifts are very smooth and noticeably shorter. Although I wish someone made a full replacement box (like Revo for my RSX). This would make the installation a 45min job.
Here is what you get out of the box:
Old Jun 28, 2003 | 03:51 PM
wojo's Avatar
I will start with the center console already removed (see pic below)as the steps necessary to do this have been covered already by other members. Basically the installation follows the same path as the B&M Short Shifter, so I will only focus on 2 most important issues (obstacles)
Old Jun 28, 2003 | 03:53 PM
wojo's Avatar
Obstacle #1: What you see inside the red rectangle is a retaining bracket. Once you remove the stock shifter rod from the box, you will notice that the bracket won’t come-off. At this point you have 3 options:
1. Cut the bracket in half and order a new one from Mitsubishi ($20)
2. Cut the rod in half and be able to use the existing retaining bracket. The stock rod can be welded together later, if need be
3. Use a commercial press and press the ball from the shaft
I ended up cutting the rod in half as I didn’t want to wait for the new bracket from Mitsu. I am going to make a suggestion to the guys at Perrin to perhaps include the new bracket as part of the kit in the future.
Old Jun 28, 2003 | 03:54 PM
wojo's Avatar
Obstacle #2: In order to be able to adjust the shifter to shorter throws, you will need to cut (trim) a rectangular piece from the existing box. I marked this on the photo below.
Old Jun 28, 2003 | 03:55 PM
wojo's Avatar
Here is a close up of that area. You need to cut fairly close to the 12mm bolt on the right. If you don’t you will not be able to put 1st and 2nd gears. I have highlighted this area on a close up below.
Old Jun 28, 2003 | 03:57 PM
wojo's Avatar
Here’s a final picture after all has been put back together. I have also changed my shift knob (Momo Cobra). I hope this helps you and saves you some time during your installation.
Old Jun 30, 2003 | 05:05 AM
leonard_shelby's Avatar
very nice... similar height.. but much shorter shifts ? maybe 50% less ?
Old Jun 30, 2003 | 06:04 AM
wojo's Avatar
I think the height is a bit taller than stock, but that is probably caused by the new shift knob. Nevetherless, I will soon compare it to a stock height.
The shifts definitely "feel" shorter, but it would be impossible for me to quantify the actual difference. If i was gonna guess, then it's 40-50%?
Old Jun 30, 2003 | 06:19 AM
cool... I have the mitsu aluminum shift knob ( which feels shorter then stock) .. maybe I'll hack off 1/2 the threads if the Perrin feels too high
did you pickup the shifter from vividracing ?
Old Jun 30, 2003 | 06:22 AM
wojo's Avatar
No, I bought it from Nino (www.ninosautoaccessories.com) for $180 shipped. Good luck with it!
Old Jun 30, 2003 | 06:28 AM
sweet .. I'll have to give that a shot
Old Jul 1, 2003 | 09:55 AM
Shahul X's Avatar
wow, good job wojo...maybe I'll get you to help me install mine?
-shahul
Old Jul 3, 2003 | 06:29 AM
joofntool's Avatar
AL didnt seem to mention having to cut anything when he installed this..or anything about the 2 obstacles..hope he reads this post and responds
Old Jul 3, 2003 | 06:32 AM
wojo's Avatar
I think he used a commercial press, but let him respond
Old Jul 12, 2003 | 09:47 AM
Vivid Racing's Avatar
Since we are Perrin's main distributor for EVO products, I will talk to them about the install instructors to get a better picture setup step by step.
We will also load them on our site for full detailed instructions at www.vividracing.com
Thanks
Vivid Racing
