Air/Fuel Gauge Install
Old Jun 30, 2003 | 02:29 PM
SikWitIt's Avatar
Where did you guys tap in the ECU? Which color wire is it and what number so I know I'm getting the right reading. And also Where did you ground it?
Thanks guys
Old Jun 30, 2003 | 11:29 PM
EVOlmike's Avatar
For my air fuel I didnt have to tap into the ECU. All you need to do is tap into the sender wire from the front oxygen sensor(the white wire under the plug cover on the ECU side of the harness(opposed to the sensor side). Then run a ground and a wire for llumination and your set. If this doesnt make sense I can post pics if you want,.
Old Jul 1, 2003 | 06:29 AM
SikWitIt's Avatar
If you'd post a pic that would be great
Thank you EVOlmike
Old Jul 3, 2003 | 01:22 PM
EVOlmike's Avatar
ill try to do it tonight and post the pic tomorrow or sat at the latest.
Old Oct 8, 2005 | 04:42 PM
Eva01's Avatar
Can you please post a pic of this? I have mine that I am finally doing and will tap into the 02 sensor instead of the ECU.
Eva01
