RRE Cam Install Video
Old Oct 23, 2007 | 08:16 PM
MasterNater's Avatar
I found this on streetfire tonight. I had not yet seen a video on a cam install, and I figured it might help out a few people. There is a disclaimer that says it's not suppose to be used as a write up or tutorial, but I think it's pretty good anyhow.
http://videos.streetfire.net/video/e...d00128e555.htm
Old Oct 23, 2007 | 08:40 PM
dudical26's Avatar
very cool video, nice find.
Old Oct 23, 2007 | 08:54 PM
Evoryder's Avatar
definitely a good vid
Old Oct 23, 2007 | 09:07 PM
Noe18's Avatar
i wanted to hear her run before and after
Old Oct 24, 2007 | 04:32 PM
The only thing I would have liked to see in the video was bleeding the lifters. I've seen some people post that you technically don't need to bleed them, and then other people (including vendors) say it's a must. I've never done it personally. I've read about how to do it, but it's always nice to actually SEE someone do it step by step, much like this video...it's one thing to read about a cam install, but much easier to watch someone do it.
Old Oct 24, 2007 | 04:43 PM
DsmAwdTurbo's Avatar
The only thing that I see so far thats wrong is the fact that the cam cap bolts should not be torqued to 20-25 fl lbs... Its 14-15 ft lbs...
Old Nov 2, 2007 | 06:34 AM
iamdace's Avatar
any idea how much different the process would be for a mivec motor?
Old Nov 5, 2007 | 07:36 PM
This was taken from another post about installing cams on a mivec engine...
Originally Posted by GregGSC
Pointers...
The little Cap on the mivec gear is made of aluminum and requires 32 N-M can be broken very easily it uses a 14mm Allen. Make sure you buy one that will work with your tq wrench.
you can either stuff a rag in under the mivec gear when you remove the aluminum cap it will spill some oil out of it. Keep that off the timing belt. you can zip tie the belt to the gear and use the timing belt tensioner tool just like on an 8. the 9 mivec doesn’t require any bleeding. and as far as the lifters go, not really necessary unless you have the car sitting for days or weeks.
One thing to watch out for if you remove the timing belt completely. Watch the Oil Pump gear and make sure that it doesn’t move. There is a balance shaft behind it and that can actually go 360 degrees out, and all the marks will line up, but it will be out. it will cause the motor to vibrate badly at about 4k rpms plus.
Old Nov 5, 2007 | 10:27 PM
RevMoto's Avatar
Same thing except you basically install both cams like the intake cam. Also the intake cam uses a 14mm allin key instead of a bolt on the cam gear.
Old Nov 15, 2007 | 12:25 PM
coffeeslug's Avatar
He makes that look SO easy. I am more tempted than ever to do this myself even though I've never done cams before.
Old Sep 19, 2010 | 09:42 AM
ta ace's Avatar
bad *** video! just did mine haha took about 2 hours ( taking my time) piece of cake..
Old Mar 9, 2011 | 08:50 AM
boost_me's Avatar
i needed this more than you know... thanks!!
Old Mar 15, 2011 | 12:31 AM
No problem. I'm glad this is still helping people, after all these years.
Old Feb 18, 2012 | 05:22 AM
PatricksEvilEvo's Avatar
This video is awesome, you're saving me from paying 8 hours in labor
Old May 6, 2014 | 09:51 AM
Dannyz32's Avatar
Hey I tried to watch it and it takes me nowhere. Just to some "install this app" page.
StreetThisEvo
Oct 13, 2014 11:44 AM
illeagle
Mar 14, 2014 06:05 PM
ak47po
10
May 12, 2010 10:37 AM
WarmAndSCSI
132
May 9, 2010 12:32 PM
Blue Evo 8
Sep 29, 2009 11:10 PM
