Where the heck is the coolant drain plug
Old Oct 29, 2007 | 01:27 PM
Eclipsing's Avatar
I'm installing an engine block heater, and I have to put it in place of the coolant drain plug, but I have no idea where it is. I searched forums and everything, and I can't figure it out. Pics anyone? Detailed info? ANYTHING!
Old Oct 29, 2007 | 01:29 PM
TouringBubble's Avatar
From the front of the car, bottom left corner of the radiator. It's a wing nut looking drain ****. (Apparently drain **** is a bad word)
Old Oct 29, 2007 | 01:35 PM
Eclipsing's Avatar
Do I have to remove the plastic shroud to get to it?
Old Oct 29, 2007 | 02:37 PM
Eclipsing's Avatar
Well I took all the shrouds off and I still dont see it. I think im an idiot.
Old Oct 29, 2007 | 02:40 PM
56Hotrod's Avatar
If you are under the car looking upwards, with the timing belt on your right...find the radiator's lower right corner. The drain plug is pointing directly aft in the lower right corner. It is black and resembles a flat head screw driver blade for turning. I'm guessing it is about 3/8" wide. Oh, and it is plastic or nylon.
Old Oct 29, 2007 | 02:42 PM
56Hotrod's Avatar
Item #1
Old Oct 29, 2007 | 02:50 PM
Eclipsing's Avatar
You beautiful bastard, I love you.
Old Oct 29, 2007 | 04:35 PM
Eclipsing's Avatar
I was looking all over for some huge brass plug, and there was the little plastic black thing. Thanks guys.
Old Nov 7, 2007 | 08:52 PM
timmiii's Avatar
So all you have to do is let the old coolant drain out from that hole and then put the new coolant in?
Old Nov 8, 2007 | 06:17 AM
HOSTILE_EVO's Avatar
Thats it. Be careful that you dont completely butcher your drain plug like i did. Its easily done as it is cheap plastic!
Old Nov 8, 2007 | 06:24 AM
MrMejia's Avatar
ahhh but wait there is another plug on the engine block which is twice as difficult to get to. That one is a brass plug that drains the water jacket in the block. If you absolutely need to which you probably do you should take this off and its located below the intake manifold near the aluminum water hose that goes to the water pump.
Old Nov 8, 2007 | 06:25 AM
MrMejia's Avatar
ooops ... my bad don'd worry! no need to take that one off. hehe.
Old Nov 8, 2007 | 06:37 AM
rice_rocket88's Avatar
Doesn't the engine block heater go there.. not in the radiator?
Old Nov 8, 2007 | 06:45 AM
ElectricEvoIX's Avatar
perfect info, I've been looking for it myself so I can install my samco hoses
what kind of coolant does our car come with OEM, or what do you guys normally replace it with once drained?
Old Nov 8, 2007 | 06:50 AM
Joshs EVO's Avatar
The car comes from mitusubishi filled with cool aid, just refill your radiator with either fruit punch or the blue stuff and you car will run sweet.
