Apexi tt wire hook up w/ pics
Old Jul 15, 2003 | 08:45 PM
bpclements's Avatar
Here's a quick run down on the install of my apexi tt. It would help to become familiar with the Evo ECU pinout before beginning. RRE has been nice enough to host this on their website and it can be found here, ECU Pinout The two pins we are concerned with is the Chassis Ground on pin 26 and the Front O2 Sensor on pin 76.
Click here for Pics and how to.
First you have to take the glove box out.
Old Jul 15, 2003 | 08:51 PM
bpclements's Avatar
Cool
Just take out the little clip on the left side of the glove box. Just slide it foward to pull it out. Then push out the other stop on the right side and drop the box all the way down and drop it out.
Next pull the bottom cover plate out foward.
Old Jul 15, 2003 | 09:15 PM
bpclements's Avatar
Here is the ecu plugs. The ground goes on the first plug on the left and the o2 wire goes on the last plug on the right.
Old Jul 15, 2003 | 09:31 PM
bpclements's Avatar
Here is where the ground connects. It is the very last black wire on the bottom right of the first connector. You can use the pink quick connects for an easy install for these wires. Make sure that you clamp the metal piece all the way down for a good connection.
Old Jul 15, 2003 | 09:40 PM
bpclements's Avatar
Next is the o2 voltage wire. It is the white wire located on the last connector. It is on the top row 6 pins in beginning with the first pin and counting to the right.
Old Jul 15, 2003 | 09:45 PM
bpclements's Avatar
Here is where I mounted mine for easy viewing of afr's and o2 readings. I used double sided tape to mount it.
Old Jul 15, 2003 | 10:02 PM
cky3396's Avatar
lookin good, nice job with the write up
Old Jul 15, 2003 | 10:10 PM
bpclements's Avatar
Thank you.
Old Jul 16, 2003 | 11:47 AM
bpclements's Avatar
If you need to hook up the ignition harness you can click here for directions. The Evo uses the same harness as the 2G 95-99 eclipse.
Old Apr 25, 2004 | 12:48 PM
d2sEvo's Avatar
So this will basically be the same install with the blitz fatt tt but with out the o2, air fuel readings depending on the features of the tt. I have me a blitz fatt cause i herd that some of these features are not that accurate. Will my main question is that this is all the same install for any tt? thanks alot
Old May 26, 2004 | 10:07 PM
Karash's Avatar
I just installed mine, but my O2 wire was blue, not white like in this writeup. I made sure it was 6th from the last plug...so I am not sure what the difference is.
Does anyone know how to properly set the A/F and O2 Warnings on the Apexi TT? I am having some trouble there.
Old Dec 14, 2004 | 06:47 PM
Mistasparkle's Avatar
um where do i get that harness?
Old Jan 29, 2005 | 03:34 PM
MANGOOK's Avatar
I am sorry guys for being a Newbie on this item. When you install this turbo timer you will be able to see your A/f # as well as your o2 #? I am confused.
Old Mar 6, 2005 | 09:19 PM
bigjhoney's Avatar
^^ posted a long time ago, but still wouldnt hurt for an answer. The turbo timer reads your o2, and thats how it determines the a/f ratio.
Old May 13, 2005 | 02:58 PM
GOOSE_Ej's Avatar
where does the gray wire on the TT go..?? e-brake right???
