Greddy Profec e-01 install help please!
Old Jul 17, 2003 | 05:49 PM
Knight_Redwolf's Avatar
Question Greddy Profec e-01 install help please!
I am new to turbos and could use some help on installing the valve unit (replacing the stock one). On the valve its self there are three ports; COM, NO, NC. On the stock valve under the air box there are two hoses attached; one is black and the other is black with white dashes. To put it simply what hoses go to what ports???
If any of you that have installed this unit your advise would be helpful.
Old Jul 20, 2003 | 06:28 PM
QuantumEVO's Avatar
NO goes to turbo
COM goes to wastegate.
Leave the third open.
Use new lines.
Store the old lines in a safe place.
Keep the stock solenoid plugged in and capped.
Mark
www.Quantum-Racing.com
Old Jul 20, 2003 | 06:30 PM
Thanx
Old Jul 22, 2003 | 09:14 AM
QuantumEVO's Avatar
No problem.
Have fun with your "e".
Mark
Old Oct 25, 2003 | 04:17 PM
wprettyboy's Avatar
DUMB QUESTION BUT, DO YOU HAVE TO DO ANY THING TO THE FUEL PRESSURE REGULATER WHEN INSTALLING A BOOST CONTROLLER??
Old Oct 26, 2003 | 12:45 PM
Only if you plan to boost more than 25 26 psi. Than you also need Race gas too.
Old Oct 27, 2003 | 07:43 AM
QuantumEVO's Avatar
Turbocharged cars already have a rising rate fuel pressure regulator to adapt for higher plenum pressures.
Mark
Old Oct 31, 2003 | 05:23 PM
wprettyboy's Avatar
but the book shows going from the fuel pressure regulator to the boost controller. i have the greddy profec b spec II
Old Oct 31, 2003 | 05:45 PM
Quickshift's Avatar
try this out
http://www.roadraceengineering.com/greddy_profecb2.htm
Old Nov 1, 2003 | 11:58 AM
imsonastie's Avatar
so is it pretty basic to install a profec 2
FullBlown
88
Dec 30, 2018 04:06 PM
extremepsi
Vendor Classifieds
17
Apr 17, 2017 03:34 PM
EVO8
Mar 24, 2003 11:05 PM
