Side Markers Removal
this is easy, undo the few clips of the plastic piece to the fender that the marker is on, stick your hand in there and you will feel a plastic clip on the side marker, push that down with your finger and push it out at the same time and it will pop right out, undo the plug and there you go, very very simple you do not need tools but a screw driver to take off the plastic philip screws on the fender liner
**do not try this from the outside, that is wrong, ignore the posts above**
TwinTurboM3
May 19, 2013 10:42 AM
