Instrument Cluster Surround
Old Jul 23, 2003 | 02:33 PM
EVOFREAK's Avatar
Hey has anyone installed the Instrument Cluster Surround on their EVO? I see the 2 screws by the Instrument Surround. So do you just need to unscrew thoes and then what. Does it just clip into place? Thanks for your time
Marc L
Old Jul 24, 2003 | 09:34 AM
wmcorcor's Avatar
I did it. The instructions from Mitsu call you you to disconnect the batery first so you can remov ethe wiring harness from the gauge cluster. I was able to pull the two screws from the surround and slowly work the clear plastic cover off by releasing the clips (top & bottom), then sliding the surround in place. It is held in place by double-stick pads. B ecareful not to fingerprint the clear cover or scratch it trying to reove the finger prints. It's pretty delicate. Also be careful not to break the clips. All in all it was fairly easy and since I did not undo the electrical plug on the cluster I didn't have to remove the negative battery terminal.
Old Nov 8, 2003 | 10:17 AM
jlanceroz's Avatar
Can you post a picture of what your instrument panel looks like.
Old Nov 8, 2003 | 11:41 AM
wmcorcor's Avatar
Best I have now...
Old Nov 8, 2003 | 11:43 AM
wmcorcor's Avatar
One more
raidokoiv
Sep 23, 2016 04:46 AM
k0lok0yboi
Apr 3, 2016 10:00 PM
MITVRX
May 1, 2007 03:39 PM
Talon
Feb 12, 2006 07:49 AM
travelsize420
Jan 9, 2005 07:07 PM
