Request tranny fluid Help!
Old Sep 14, 2008 | 07:53 PM
VajEvo's Avatar
Anyone know where I can find, How to change tranny fluid or add fluid to tranny?
Old Sep 14, 2008 | 08:37 PM
Kracka's Avatar
Remove filler bolt, remove drain bolt, reinstall drain bolt, fill tranny with your fluid of choice until it starts to leak back out, reinstall filler bolt, enjoy Same easy steps for your transfer case and rear differential.
*note*
Make sure the crush washers are on the bolts and in good shape. If they look damaged replace them; cheap Mitsu part. Also clean the trash magnets on the drain plugs the best you can.
Old Sep 14, 2008 | 08:46 PM
Nkryptd1's Avatar
Here is a link to step by step instructions with photos...
http://evomoto.com/tech_info.php?tPa...54dd85d72cea64
I always buy my fluids from...
www.slowboyracing.com
but I know other vendors have them as well. Good Luck
Old Sep 15, 2008 | 12:32 AM
pjb00stin's Avatar
+1 o nthe crushwashers.i say you just change them even if they 'look' ok
Old Sep 15, 2008 | 11:12 AM
Kracka's Avatar
Definitely no harm in changing the crush washers! I reused all mine for the first change but I will be replacing them next time.
Old Sep 16, 2008 | 09:03 PM
VajEvo's Avatar
Thanks alot everybody!
Im going to give it a shot this weekend.
