How to swap auto transmission to manual transmission on my Evo-7 GT-A??
Old Jan 13, 2009, 03:12 AM
seankhan's Avatar
Guys I need help to convert my A/T to M/T on my evo-7 GT-A? Pls if u can mention the parts which ll need for the convertion and also mention the advantages & disadvantages.
Old Jun 14, 2009, 11:34 AM
Josh Grind's Avatar
Unhappy GTA conversion
Did you get any responses or solutions to your swap question cuz I need to do the same swap?
Old Jul 21, 2009, 10:30 AM
nads1978's Avatar
Bump
Old Oct 25, 2009, 12:58 PM
nads1978's Avatar
I have now done this conversion, still want any info?
Old Nov 9, 2009, 01:05 AM
monsta's Avatar
It would be great if you did a run down of what you did and any issues that you ran into. You also mentioned to me in a PM about reflashing using the Tephra mods
Old Nov 9, 2009, 08:25 AM
nads1978's Avatar
I will be doing a full write up of the job on the MLR, but will also try to make it a reference point for all things GTA. ECU/wiring/drive-train differences etc etc. (will update this thread when I have done it)
Yep, got Tephra's 5.10 [96260009-v5.10fix2-mods] running on my GTA ECU (running manual box remember), The valet part worked okay - didn't try much else, as when I took the car out, I had to change back to my GTA ROM. I must not have changed all the settings over - got 'judder' when on boost (maps/timing - anything else?)
Did you have a look at the pinout? Does it correlate with any work you have done previously?
Old Nov 11, 2009, 01:05 PM
seankhan's Avatar
hey nads1978 i m happy hear that someone done the conversion successfully. Can u tell me is it difficult or not. Yeh I m dying to do it. Pls help what are the thing i need for the conversion.
Old Nov 11, 2009, 01:16 PM
nads1978's Avatar
Hi Sean, I've seen you over on the MLR.
Here is a quick rundown...
Parts required:
  • 5/6 speed manual gearbox
  • Gearbox mounts
  • 5/6 speed Linkage, selector & knob.
  • Clutch pedal & mount
  • Release (slave) Cylinder
  • Master cylinder
  • Clutch pipe work
  • Flywheel + bolts (different length GTA/Manual)
  • Clutch
  • Release bearing
  • Front left drive shaft (different length GTA/Manual).
  • Centre console (front part only)
  • Reverse connector plug
The speedo will not work, as the GTA calculates the speed from input/output shaft speeds. I will be looking into this on my car over the next few weeks and update. This is the only issue left.
The main problem with the conversion is mounting the clutch pedal. The front of the pedal box mounts to the blank on the bulkhead, but the top of the pedal box will not mount to the chassis above, there is a gap. The manual car has an extra bracket built into the chassis. You have 2 options here, remove all the dash, and make a bracket, or, what I had done, brace the top of the pedal box with a large bracket over to the brake pedal mount.
Like I said above, I'll be doing a full write up about it on the MLR within a couple of weeks.
Regards
Old Nov 11, 2009, 01:31 PM
seankhan's Avatar
tnx mate. This is enough info for me. Yeh i want to know more about this. Check ur inbox.
Old Nov 12, 2009, 12:03 PM
seankhan's Avatar
another thing what about the wiring & ecu??
Old Nov 12, 2009, 12:08 PM
nads1978's Avatar
As mentioned speedo is not working but I plan to rectify this next week.
Gearbox loom modifications:
There are 4 plugs, large black, small black, large grey, small grey.
The large black plug going into your gearbox is the only one we need. It has 2 rows of pins, 4 big & 6 small. The 4 big ones are the ones we are interested in.
The pins are attached to wires coloured: (1)[brown] + (2)[Black/Yellow] + (3)[Black/Brown] + (4)[Black/Yellow]
(1)+(2) are for the reverse light switch - extend to gearbox connector.
(3)+(4) are for Neutral/park sensor - the ECU won’t allow you to start the engine unless in N or P, short these 2 out (or hide a switch in the cabin for an extra immobiliser).
Your GTA dash will still indicate when you are in reverse, and will still beep in the cabin.
Old Nov 12, 2009, 12:13 PM
nads1978's Avatar
Old Nov 17, 2009, 10:15 AM
nads1978's Avatar
Clicky
Old Jul 30, 2012, 10:56 PM
dillons13's Avatar
woulld it be easier if u get a manual car harness and instrument panel? would the speedo work that way
Old Jul 30, 2012, 11:00 PM
dillons13's Avatar
what modifications do u have to do to the manual car transfer box for it to fit into a gta car
Quick Reply: How to swap auto transmission to manual transmission on my Evo-7 GT-A??
