Throttle Cable Relocation Mod!
Old Dec 27, 2008 | 01:45 PM
Juan Martinez's Avatar
Do you think this would work on an es/ls/oz rally or ralliart?
Old Dec 27, 2008 | 01:52 PM
EvoHung's Avatar
It should work.
Old Dec 27, 2008 | 02:06 PM
Originally Posted by EvoHung
It should work.
Your tempting me. lol
Old Dec 27, 2008 | 02:14 PM
Mulholland0132's Avatar
I did this 4 years ago. ZERO problems whatsoever. I also removed all of those metal tubes sitting on the corner of the valve cover. ZERO issues as well. And mine is daily driven.
+1....I did this two plus years ago...it looks waaaaay better and I have zero issues with the throttle binding.
Old Dec 27, 2008 | 07:23 PM
biggie5252's Avatar
Originally Posted by derangedazn
will this void your warranty?
Your warranty has already been voided.
Old Dec 27, 2008 | 07:42 PM
derangedazn's Avatar
tell me about it. They voided my drivetrain after seeing my chrome valve stems.
Old Dec 27, 2008 | 07:46 PM
Wayne99gsr's Avatar
good stuff!! Alvin
I never though about it.
Old Dec 27, 2008 | 07:56 PM
silver9mr's Avatar
yea i did this last year but for some reasone i convinced myself that it felt weird to i put it back lol but i think imma do it again soon
Old Dec 27, 2008 | 08:31 PM
WWEVO206's Avatar
Nice write up Alvin.
Old Dec 27, 2008 | 10:04 PM
scheides's Avatar
EvoM Moderator
I did this on my car about 2 years ago, 30k miles or so. No problem, just be sure to test and make sure the throttle cable doesn't get kinked and thus sticky....once you go WOT and let off it may not go back down to 0 all the way. If it doesn't do it right away, it probably never will....
Old Dec 28, 2008 | 08:38 PM
JakeTheVIII's Avatar
I did it. I like it better.
Old Jan 8, 2009 | 11:04 AM
ExplosEvo's Avatar
I did this about a year ago but I just used some black zip ties and tied the cable to the underside of my strut brace. Its all black anyways. Its out of the way, and it DOES look alot cleaner around your valve cover without it. No binding of the gas pedal here.
Old Jan 9, 2009 | 12:22 PM
AIEvo9MR's Avatar
Originally Posted by LuisIX
i did it the same way your showing alvin..after a couple miles it started to get stuck
Did u lube up the cable.? That would be the #1 reason if it did.
Old Jan 25, 2009 | 10:48 AM
misfit8's Avatar
I just did the cable mod. While I was at it, I also polished the uicp. It looks alot cleaner with the cable moved.
Old Oct 14, 2009 | 05:34 PM
Rex915's Avatar
Ima do this tomarrow
