Replace Wastegate Actuator WGA
Old Nov 18, 2009 | 02:52 PM
Saleentones's Avatar
Help Replacing Wastegate Actuator WGA
Do I need to remove the radiator in order to get to the WGA? For those who replaced or upgraded their WGA, is it pretty straight forward? Any tips or advise would be much appreciated! Thanks.
Old Nov 19, 2009 | 08:22 AM
Anyone???????
Old Nov 19, 2009 | 08:23 AM
buchnerj's Avatar
It would make it much easier to get to if you removed the radiator. You could also take the turbo assembly out and drop it down, just undo the hotside to manifold bolts and drop the downpipe and turbo assembly down and take it out. Taking out the rad is just as easy though.... Look for yourself, you can see how hard those bolts are to get a good hold on, if you try and squeeze in there you are just asking for bent fins on the back of your radiator. Take the time and do it right...
Old Nov 19, 2009 | 08:24 AM
buchnerj's Avatar
There are really no tricks to swapping it out, either. Just take it off and be careful not to bend the WGA rod if it is being replaced...
Old Nov 19, 2009 | 08:39 AM
tweakdsm's Avatar
uninstall: upper pipe, entire intake, side fan, -drain coolant from radiator - 10mm plastic screw use 10mm socket, on left side if you stand in front of your car, take radiator out...
(2) 12mm bolts that hold wga.
i think best way to replace wga, easy and clean.
install everything back in, fill the coolant up top,with cap off, start the car , ones u see coolant going up , shut the car , add more coolant, snap cap back in,
done.
Old Nov 19, 2009 | 08:43 AM
mitsumanny's Avatar
My friend just removes it from underneath its a lot easier, nothing else to remove and takes about 10 mnutes. Just jack up the front (if you need to) and have at it.
Old Nov 19, 2009 | 08:47 AM
Thanks guys!
Old Nov 19, 2009 | 08:49 AM
tweakdsm's Avatar
np just pm me if you have any questions. GL
Old Nov 19, 2009 | 09:02 AM
ROGERV's Avatar
Originally Posted by Saleentones
Thanks guys!
I have removed the wastegate off my car many times and never had to remove the radiator or any other parts other than the wastegate.
The trick is you need a swivel head rachet. If you don't have one I would get one. It makes the job much easier.
JDavenport
Apr 18, 2014 02:01 PM
michael knight
Dec 16, 2013 05:17 PM
Tekniq
Jan 5, 2013 06:32 AM
mrfred
Oct 8, 2007 04:54 PM
