BR Underhood metal bushing install
Old Dec 24, 2011 | 11:07 PM
  #31
716amg55's Avatar
nice going to be ordering these up now thanks
Old Nov 23, 2012 | 03:05 PM
  #32
benihana242's Avatar
Combined with the shifter base bushing this is an excellent upgrade and preventative mod.
Don't be intimidated by the metal, they are not obnoxious by any means.
Old Mar 12, 2013 | 06:10 AM
  #33
Terror Rising's Avatar
Does anyone have the dimensions for these? I'm going to make them myself since I have access to a lathe and aluminum. I'm just trying to save time by making them in advance rather than making them after I remove the old bushings.
Old Aug 18, 2013 | 05:57 PM
  #34
Desipride's Avatar
Putting these in my car this week, along with a Competition Stage 2 Unsprung Clutch, ACT Pro-Lite Flywheel, and SS Upper and Lower lines. I've been getting grinding in 4th, clutch lockout in almost every gear above 6500 RPMS, Clutch Slippage at times going above 25 psi.... Will let you guys know how much of a difference this all makes
Old Nov 25, 2013 | 10:52 PM
  #35
itsmekai's Avatar
Decent upgrade for the cost, straight forward install too. Pushing out the old bushings was definitely the hardest part.
Old Mar 22, 2014 | 07:13 PM
  #36
Trini Evo's Avatar
I spent an hour trying to get the old bushings out with no luck. I soaked them in wd40 and put it back together for now. Any tips?
Old Mar 23, 2014 | 02:23 AM
  #37
charlie.tunah's Avatar
Are they stuck on the posts? Or stuck in the cables? Are they stock?
I found the stock bushings to be quite easy to take apart with some pliers.
Has anyone else with these bushings had trouble getting the pin back in the big bushing? Mine is way too thick. Stocker barely fits, BR bushing is the same thickness as the post. Cant even come close to seeing the pin hole.
Old Mar 23, 2014 | 05:21 AM
  #38
Trini Evo's Avatar
Yea the stock bushings are are basically seized on to the linkage.
Old Mar 23, 2014 | 06:16 AM
  #39
9evolution's Avatar
Mine were siezed on there as well. Shop had to cut them off. For a quick "easy" install it eas really a pain
Old Mar 23, 2014 | 09:38 AM
  #40
Trini Evo's Avatar
Figured it have to cut them off....was it worth the hassle?
Old Mar 25, 2014 | 06:46 PM
  #41
9evolution's Avatar
worth the hassle for me, i had the shop do it LoL. Definite improvement over the stock set up
Old Mar 28, 2014 | 07:07 AM
  #42
Here is a picture of the lower big bushing that appears to be too thick. No one else has had this issue?
Attached Thumbnails BR Underhood metal bushing install-img_20140328_060559040.jpg
Old May 10, 2014 | 06:39 PM
  #43
JerryIrvine's Avatar
Installed today.
Didn't have the issue that Charlie mentioned.
Ex MR? Could it be a 5 speed vs 6 speed issue with the bushing size difference?
Jerry
2005 GG MR
Old Sep 15, 2014 | 09:30 PM
  #44
jfetty's Avatar
Just put mine in today with the shifter bushings. Amazing difference. It's a lot easier to shift hard now where the old bushings and tranny were getting a little tired of me beating up on them. Poor car is getting old but definitely recommend this.
Old Oct 17, 2014 | 11:51 AM
  #45
auffy16's Avatar
i'll be installing mine this weekend! Thanks for the time you put into making this!
