Removing the rear differential (diff)
Old Apr 23, 2012 | 08:30 AM
  #31
EGbeater's Avatar
Originally Posted by black_beauty
From where exactly should I be "gently prying" on the axles?
There's a bump on the back side of the diff case/rear cover, where one of the bolts for the back cover goes in. You can use that as a fulcrum for your pry par. Rotate the axle so that you've got the most amount of area to sit the end of the pry par under:
You can also use the entire flat vertical edge of the rear diff (this is on the passenger side, with the axle already popped out 3/8" or so):
Keep in mind that it may be easier to pop the axles out slightly just to get it past the snap ring groove while it's still up/mounted to the car. Once the diff is fully disconnected (both 19mm head bolts that attach the diff's mounting ears to the car, and the three 17mm head bolts on the back of the diff) it's difficult to use the prybars to pop the axles out because the diff will flop around and move as you try to get leverage.
A pic of how I use a HF jack to lower the diff and control its height during the process:
Old Apr 23, 2012 | 11:54 AM
  #32
black_beauty's Avatar
thanks man that is exactly what I was looking for, I tried and Idk about this "gently" business. Mine seem to be a little stubborn.
Old Apr 23, 2012 | 02:19 PM
  #33
EGbeater's Avatar
Maybe "gently" wasn't the right word. You do have to use some force to generate enough leverage with the prybar (depending on how long the prybar is of course). But it very easy to do with the right tool/technique.
Old May 3, 2012 | 03:28 AM
  #34
evox4b11turbo's Avatar
Thumbs up
Thanks alot for the write up man!! My rear diff is leaking and this write up just saved me a lot of money!!
Thanks A lot!!
Old Jun 2, 2012 | 07:39 PM
  #35
I know it says to put mating marks on the driveshaft but I bought another rear diff as mine was ruined. Should it be ok to just put it back together?
Old Aug 24, 2012 | 02:42 PM
  #36
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Awesome thread, doing this tomorrow.
Here are the torque specs for future reference:
DIFFERENTIAL CARRIER ASSEMBLY
Propeller shaft and differential companion flange connecting nut - 32 ± 2 N·m (24 ±1 ft-lb)
Differential mount bracket bolt - 88 ± 10 N·m (65 ± 7 ft-lb)
Differential mount bracket to differential support member connecting bolt - 120 ± 10 N·m (89 ± 6 ft-lb)
Differential support member mounting bolt - 88 ± 10 N·m (65 ± 7 ft-lb)
Differential support arm to differential carrier mounting bolt - 73 ± 12 N·m (54 ± 9 ft-lb)
Differential support arm mounting nut - 73 ± 12 N·m (54 ± 9 ft-lb)
Rear crossmember mounting bolt - 88 ± 10 N·m (65 ± 7 ft-lb)
Toe control bar mounting bolt - 69 ± 9 N·m (51 ± 7 ft-lb)
Differential cover bolt - 36 ± 5 N·m (26 ± 4 ft-lb)
Drain plug - 64 ± 4 N·m (47 ± 3 ft-lb)
Filler plug - 49 ± 9 N·m (37 ± 6 ft-lb)
Drive gear and limited slip differential case mounting bolt - 84 ± 4 N·m (62 ± 3 ft-lb)
Companion flange self-locking nut - 186 ± 29 N·m (137 ± 21 ft-lb)
Bearing cap bolt - 37 ± 2 N·m (27 ± 1 ft-lb)
REAR SUSPENSION ASSEMBLY
*:To prevent bushings from breakage, the parts indicated by * should be temporarily tightened, and then fully tightened with the vehicle on the ground in the unladen condition.
TRAILING ARM MOUNTING BOLT - 147 ± 9 N·m* (109 ± 6 ft-lb)*
LOWER ARM CONNECTION - 88 ± 10 N·m* (65 ± 7 ft-lb)*
LOWER ARM ASSEMBLY MOUNTING BOLT (Camber Adjustment) - 93 ± 15 N·m* (69 ± 11 ft-lb)*
LOWER ARM ASSEMBLY TO SHOCK ABSORBER CONNECTING BOLT - 88 ± 10 N·m* (65 ± 7 ft-lb)*
Old Nov 15, 2012 | 10:26 AM
  #37
Blitz's Avatar
Originally Posted by Solo II Evo
It won't fall to the floor, but it makes the moustache bar bolts hard to take out since the moustache bar has flexible rubber bushings (an excellent time to install that Energy Suspension Differential Bushing Kit!)
I will be dropping the diff next week and am a bit confused about the bushings. Car has 75k on it so I figure while I'm down there I might as well put in new OEM bushings (I hear the poly ones make the car unbearable on the highway).
Which bushings do people refer to when they talk about replacing rear diff bushings? A, B, C? All?
Old Feb 6, 2013 | 07:17 PM
  #38
bhmax's Avatar
Just pulled mine out. Only had to remove the axle back and rotate the sway bar down. Was expecting to have to remove something else on the suspension, but nope.
Old Apr 16, 2013 | 12:15 PM
  #39
heel2toe's Avatar
I'd like to be the 3rd person to say that dropping the diff was quite simple and didnt require nearly as many things to be removed in order to get it out.
1) Jack up the car and set it on jack stands
2) Drain the fluid
3) Remove the axle back portion of your exhaust
4) Unbolt sway bar end links
5) Pop axles loose. You will not have enough room just yet to get them out but definatly pop them loose now
6) Unblolt driveshaft
7) Unbolt 3 17mm bolts holding diff to mustache bar
8) Unbolt 2 diff side mounts making sure to have a jack positioned under there to balance the weight of the diff.
9) Slowly lower it down, pull out one axle and then pull out the other one and viola it is out.
Old Apr 16, 2013 | 12:20 PM
  #40
Bassicfun's Avatar
2) Drain the fluid
^^^ This... OVER AND OVER... I have had mine out more times than I care to, at least it is simple now. AMS Exhaust here, and it does NOT need removed to get to the rest.
Old Apr 16, 2013 | 12:47 PM
  #41
heel2toe's Avatar
Hmmm, I wonder if I could have gotten away without removing my exhaust (RMR in my case). Im not sure if it gave me easier access to my passenger side endlink. Without looking under my car I am not sure. Oh well, I was just glad that I didnt have to pop off control arms and all that other crap.
Old Apr 16, 2013 | 01:10 PM
  #42
flabber's Avatar
Nice info
Old Apr 27, 2013 | 09:10 PM
  #43
AndyCT9W's Avatar
2) Drain the fluid
Thanks for the write up guys, I'll be getting stuck into this in the next few days. One question, it's not necessary to remove the rear wheels or the rear axle nuts?
Old Apr 28, 2013 | 07:28 AM
  #44
EGbeater's Avatar
No.
Old May 5, 2013 | 09:56 PM
  #45
AndyCT9W's Avatar
I'm nearly there! But I am having trouble with this step.
I just can't get the axles out, any tips/hints or something stupid I might be doing?
Edit: Should mention, it seems as if I can't get enough slide room to slide them out of the diff.
