Is my turbo timer working correctly?
Old Oct 31, 2003 | 09:15 PM
Invoice EVO's Avatar
Veteran: Air Force
Hello all, well I just got a Greddy Turbo timer installed along with the harness. After the install I noticed that when I take the key out it almost seems like it does a "brown out." The engine wants to shut down, then maybe a half second power is constant untill the timer has count downed. I had a WRX with a Greddy T. Timer and it never did this, the transistion was smooth. Any toughts on what I should do? Will this hurt the car?
Old Oct 31, 2003 | 09:56 PM
HIGH REV's Avatar
Do you have anything else running in the car while it's turbo timing?
Old Oct 31, 2003 | 10:32 PM
Veteran: Air Force
No, I make sure everything is turned off. The funny thing is, it won't "brown out" after I turn the key and take it out, then put the key back in and switch past acc. and take it out again to try to duplicate the problem.
Old Nov 17, 2003 | 09:48 AM
ex-honda's Avatar
I just installed mine and it does the same thing. I think what it does is when we turn the key off, it switches over to the TT. I believe that is where we get that half second delay. other than that it works fine.
Old Nov 17, 2003 | 04:29 PM
jemm's Avatar
did you use the greddy harness? some people have reported problems with it on this forum.
Old Nov 17, 2003 | 04:32 PM
alfredob1's Avatar
I think it does it when you turn the key slowly. If you're quick about it, the TT kicks in right away and it doesn't "brown out".
Old Nov 17, 2003 | 04:42 PM
SilverEvo8owner's Avatar
i think its somehting about the evo
I had the HKS type 1 on the evo and it did the same thing.
Its now on the STI and it doesnt do it at all.
Old Nov 17, 2003 | 05:00 PM
alex_alex's Avatar
mines fine, but i have the HKS type 1 and the type 1 harness.
from what i have seen, if your using a brand for the harness different from the timer, it may lead to problems.
Also, check to see if your wire connecting to the e-brake is on tightly.
And lastly, check to make sure that you have a good ground. If you're working underneath the steering column, youll see a good ground point that actualy has something else grounded there already.
Old Nov 18, 2003 | 12:05 PM
imsonastie's Avatar
i also have the greddy tt with the harness. i get the same thing. im not worried. but......
sometimes when i go to start the car it counts down when i start it and i have to turn the tt off then back on again. anyone get this?
Old Nov 19, 2003 | 04:51 AM
Veteran: Air Force
Yeah mine does that also. It will count down, then go back to the setting. Also I noticed if you turn the key real slow when shutting down the car, that the car will almost cut off then the TT kicks the car back on. So I make sure I make quick key turns.
Old Nov 21, 2003 | 02:02 AM
w2pac12345's Avatar
My car doesnt do that. You cant even tell I took the key out.
Old Nov 21, 2003 | 11:49 AM
AltezzaRoku's Avatar
i'm using the GReddy harness and my car does the same thing. People who have used the HKS harness don't seem to get this problem. check it:
https://www.evolutionm.net/forums/sh...threadid=44486
Old Nov 22, 2003 | 09:07 AM
Veteran: Air Force
Cool, I'll have to give it a try.
Old Nov 22, 2003 | 10:03 AM
jemm's Avatar
Dude, the HKS MT-6 harness should cure your problems....
Old Dec 3, 2005 | 09:13 PM
vr4_211's Avatar
Please help...
I installed a GReddy Full Auto Turbo Timer 4 months ago. Everything worked fine until the other day. My brother borrowed my car and when he got home he left the key in the "ON" position. I woke up the next day and found out that my batery got drained. I jumpstarted it but it still won't start so I replaced the battery and my turbo timer doesn't count down anymore.
It still turns on and all the other features seem to still work except for the timer itself. Sucks! After a drive, when I turn the ignition off, both the timer and the engine shuts off right away.
How do I reset the timer (if it's even possible)?
Any help would be greatly appreciated.
