question: how to remove cylinder head?
Old Jun 20, 2010 | 05:45 AM
socalmr's Avatar
just curious how hard it is and how much time it would take to remove a cylinder head in an evo 9
Old Jun 20, 2010 | 06:05 AM
Evoryder's Avatar
Did mine in about 6hours ...no rush.
Remove harnesses off rocker cover Inc. Injector clips
Fuel feed return line hoses plug and move to side.
Drain coolant. And remove hoses that attatch to head
Optional remove or leave intake mani on. If you remove intake mani you gotta take all that junk off.
Remove rocker cover
Remove cam gears same as removing cams, zip tie, tensioner tool etc
Remove head bolts
If everything has been remved from head it should lift easy
install is reverse of everything above.
_des_
Apr 4, 2017 01:47 PM
Tw3NTy0n3
May 21, 2016 11:24 PM
randomdriver
Dec 3, 2013 11:54 AM
ShapeGSX
65
Apr 3, 2013 05:23 AM
Skippys8
May 14, 2012 09:53 AM
