AEM EUGO - white wire - Evo Scan ??
Has anyone wired the white wire from their AEM Eugo directly to the stock ecu (without using a serial cable)? Similiar to how this is done with dsmlink in a 2g:
http://www.dsmtuners.com/forums/tuni...k-logging.html
If so could you please state how you did this and if you used the rear o2 which wire this is on the ecu? (I believe its pin 75, but i'm not sure of the color of the wire). http://www.evoscan.com/technical-veh...wiring-diagram
Thanks,
Thanks,
