vaccume diagram for boost solenoid
Old Sep 20, 2008 | 09:53 PM
jmsd316's Avatar
need a picture of the routing on the vaccume lines from the wastegate/j-pipe to the stock boost solenoid for 03 evo 8
Old Sep 21, 2008 | 08:15 AM
cfdfireman1's Avatar
here you go
vacuum lines
Old Apr 8, 2011 | 07:29 PM
shadovarian's Avatar
I have been searching everywhere and I haven't came across an answer yet, so I apologize for the thread dig, but does that diagram show the OEM boost solenoid top vacuum line go to the intake tube before the turbo but after the mas? If so is that where is must go? I have an Injen tube and the Positive Crankcase ventilation line from the top of the valve cover is going to the only port on my intake tube.
Old Apr 28, 2011 | 11:49 AM
evodziobak's Avatar
yes the diagram shows the OEM boost solenoid top vacuum line go to the intake tube. My advice is get an oil catch can with an air filter and run the crankcase vent into that and this way you will free up the port on the intake tube + you will have a cleaner intake and turbo with the catch can catching oil instead of flushing it back into the intake.
Old May 2, 2011 | 01:01 AM
EVO-IX-MR's Avatar
The side of the OEM boost solenoid that normally goes back to the intake tube can just VTA, it won't cause problems. Or you can just cap it off.
babaz7
Feb 16, 2015 01:14 AM
hachansoo0413
Apr 26, 2012 07:38 AM
bryan0
Mar 6, 2011 09:00 AM
Ronnie Size
Oct 8, 2010 04:42 PM
domantas
Apr 19, 2010 08:56 AM
