oil pressure and temp instal
oil pressure and temp install
hey guys, have a quick question, i have the aem oil pressure and oil temp gauges. i understand the oil pressure one connects to here...
now where does the temperature one plug into? thanks!
I wouldn't tap into there, I have heard that it leaks sometimes because of the thread of the sensor. Best bet would be to get an oil filter adapter plate. It'll have more than enough plugs for pressure and temp senders. I know prosport sells one and I believe Greddy does also.
http://prosportgauges.com/oil-filter-adaptor-plate.aspx
so this would let me hook up both my temp and pressure gauges to one thing?
I hooked up the AEM temp gauge to the MR stock oil drain plug with a 1K ohm resistor in series to calibrate it in close... That is if you have that temp drain plug already. Quick and easy IMO.
gasolinebaptism
Mar 12, 2015 08:00 PM
Profoxcg
Oct 1, 2007 07:26 PM
