How to install OEM exhaust manifold?
I purchased the car and it has an Ebay exhaust manifold. One of the bolts is broken off that attaches to the motor. I am putting an OEM one on the car. Is this a fairly straight forward swap? Any advice welcomed.
its fairly simple. take out the 4 bolts that hold the turbo down. then theres two 12 or 14mm bolts on the bottom corners of the manifold. then theres 7, 10 or 12mm bolts that hold the manifold to the head. 3 on the bottom 4 on the top. if you spray them down with wd40 for half and hour and let them soak your shouldnt break any studs. make sure you have the right wrenches, sockets, extensions and you should be fine
Here is a pic of the broken head stud. It's one of the bottom ones that attaches to the head. Is this a pain in the *** to remedy?
Judging by the amount of rust in that picture I would get a whole new set of hardware. It wouldn't hurt to get a tap set and run it through the threads on the head to clean them up before re-inserting new studs either.
I agree. I went to the dealer yesterday and purchased the nine studs and a heat shield. I just need to get the tap set now and some anti seize.
Would just cleaning up the cylinder head exhaust stud threads with a wire brush and put some anti-seize on work as well, and potentially save a metric $hit ton of head aches? I'm just worried about more breaking off while trying to change them out.
FS[West]: OEM EVO 9 Exhaust Manifold
fugiwara
Jun 9, 2016 10:29 PM
Ralliartize It
Jul 16, 2013 03:28 AM
salvatruco2004
10
Apr 17, 2013 06:32 PM
