Walboro Fuel Pump Install EVO
Old Jan 23, 2004 | 04:03 PM
Vivid Racing's Avatar
Just got this article up on our website. A quick how-to on a fuel pump swap. Anyone can do it!
http://www.vividracing.com/index.php...c5c454221cbf8f
Enjoy.
Old Jan 24, 2004 | 02:26 AM
alex_alex's Avatar
thanks. i needed to do this. im gonna give it a try and let you know how it goes.
Old Jan 24, 2004 | 04:03 AM
Fourdoor's Avatar
Good write up, you may want to mention how much of a pain in the *** that one 8mm nut is (need a swivel socket). Also, the pictures are way to small to be any use.
Good effort,
Keith
Old Jan 24, 2004 | 04:09 AM
mister_pants's Avatar
Isn't this a repost? I though I already saw a post like this during my days as a lurker before I registered. Or maybe I'm just drunk...it is 4:00am here in cali
Old Jan 25, 2004 | 04:33 PM
Lowness's Avatar
There are two black sheets of metal under the rear seats. I know the fuel pump is located behind the driver's seat, but what is that thing behind the passenger seat?
Old Jan 26, 2004 | 12:18 AM
w2pac12345's Avatar
If u have a ECU flash do you need to get it tuned when u replaced the pump or does it not affect it?
Old Jan 26, 2004 | 12:33 AM
EvolvedDSM's Avatar
It's a few things, but we'll just call it the floater assembly for the fuel gauge to keep it simple
Old Jan 26, 2004 | 08:49 AM
MrBonus's Avatar
Does anyone have any problems with the aftermarket pump overrunning the stock regulator and putting unecessary stress on the injectors?
Old Jan 26, 2004 | 09:12 AM
GranMassaX's Avatar
http://www.evomoto.com/tech_info.php?techID=21
this write-up is much better
Old Jan 26, 2004 | 12:43 PM
Ryanmcd3's Avatar
In Timeout
Your install doc is 1/2 assed
Old Jan 31, 2004 | 06:02 PM
Fourdoor's Avatar
Re: Walboro Fuel Pump Install EVO
Originally posted on the VividRacing.com web site
Next you need to unhook the lines on the car. Use pliers to slide the clips back. Once these are unhooked, take off all bolts that hold the pump assembly down. You can now twist out the assembly. A small amount of gas will drip once you pull it out. Its OK.
That has to be the funniest paragraph in your whole install explanation! Should say "strugle for 15 min twisting and turning this son of a ***** 5" round disk out of a 4.5" square hole"
I ask you guys, did some engineer decide to make people working on the car cuse like sailors just for fun or was there some other justification for this debacle? If that damn square plate was just .5" larger in each direction the f'ing pump assembly would lift strait up without any trouble!
Keith
Old Feb 3, 2004 | 07:26 AM
Mante's Avatar
its not P/C to bash someone for trying to get info out there that will help some newbie out. Especially if the same person(s) doing the bashing have not posted anything of there own.
Old Feb 3, 2004 | 09:18 AM
Talking ...
i still love you guys!
Old Feb 3, 2004 | 09:24 AM
boostedwrx's Avatar
on DSMs, we would cut part of the sheet metal to get the fuel pump out..
Old Feb 3, 2004 | 10:54 AM
darkturbo's Avatar
it says that you will not notice any worse gas mileage but then it also say you will "just" notice for fuel being pumped faster. Wont more fuel make your mileage worse. Can anyone with this pump contest to teh gas mileage and if so do you have something to tune it with? i have the profec e-01 and emanage combo. Will that be good enough or will you even need to tune it? Will it run rich if you just installed it without any fuel control.
