HOw to remove axle?
Old Aug 26, 2012 | 09:27 PM
re-rx7's Avatar
HOw to remove axle?
Passenger side axle has a leak in the boot. Whats the easiest way to get one out? Tips?
Old Aug 26, 2012 | 10:05 PM
flymx771's Avatar
Remove:
Wheel
Axle nut
Lower ball joint nut
Sway bar end link
Then carefully use a pry bar to get it out of the tcase. There is a circlip that sits in a groove on the end of the axle which is what holds it in.
Old Aug 26, 2012 | 10:50 PM
re-rx7's Avatar
Tranny fluid need to be drained? Seems simple enough much like my Gst. Replaceing with a Oreilly axle.
Old Aug 27, 2012 | 12:53 PM
sujinX's Avatar
why not just replace the boot? i wouldnt throw on the oreilly axle. sounds like it could snap under a lot less load/shock load than oem.
heres some info on changing the rear boot. kinda similar to the front.
https://www.evolutionm.net/forums/ev...axle-boot.html
gerikivan
Feb 28, 2017 09:31 PM
Carver
Jul 18, 2016 02:30 PM
URNVS
Apr 8, 2014 01:11 PM
PromDizzle
May 16, 2011 07:33 AM
BluEVOIX
12
Nov 6, 2010 09:07 AM
