stock boost gauge connections ?
Old Feb 6, 2004 | 08:45 PM
eazyevo's Avatar
Anyone know if our evos have the connections from the factory to plug a boost gauge straight up without any cutting etc.. ? thanks!
Old Feb 7, 2004 | 10:59 AM
sir lurks alot's Avatar
just T off the vacuum line from the recirculation valve to the intake manifold. No big deal, you don't HAVE to cut anything if you don't want.
Old Feb 22, 2004 | 09:41 AM
mksevo's Avatar
boost install
just by some small T's and use another short piece between and you will not have to cut anything here is a pic of mine. hope you can see or let me know i will get closer shots.
Old Feb 22, 2004 | 10:08 AM
StreetPowerEvo's Avatar
I've read that if you T in where MKSEVO did you will get some weird readings from the boost gauge, so figured the recirc line would be better. But I also just read its bad to run the boost vacuum line over 3ft. Is that true?
Old Feb 22, 2004 | 12:09 PM
SinCityEvo's Avatar
I Tee'd mine right there and no problems. Vac and boost readings are right on. But I Tee'd mine in just north of that blue circle right in the middle of that short hose.
Edit: You can run the line more than 3 feet. in fact, my factory guages Tee in in that spot, then run to the front of the car and down and over the wheel well, through the grommet under the glove box on the side, and over to the center console. The factory guage package came with way more than 3 feet of hose to run.
Old Feb 22, 2004 | 03:46 PM
Thx for the info and clearing things up
Old Feb 22, 2004 | 06:31 PM
mksevo's Avatar
just FYI i did T at the bottom hose first but seen how it went the the feul pressure valve, i began to think what it this causes a malfuntion and gauge or hose breaks or leaks then i loose boost and fuel pressure bad idea. at least here you dont effect the fuel system if there is a malfuntion. I did both and the readings were identical.
evo9atic
Jun 13, 2017 08:17 PM
CaptianSellout
16
Apr 20, 2011 06:57 PM
flashy
Jan 29, 2007 09:14 AM
LEVIII
Apr 28, 2005 10:56 AM
petem
23
Apr 25, 2003 09:28 AM
