How To: Custom PS/AC Delete
That's awesome they gave you the information / instructions to build the kit. Did they tell you which belt to run?
Also if you wouldn't mind, could you post pictures and list what's needed, when you're finished ? This would be great for anyone else attempting to do this, especially since not kit is available currently.. I'm also interested in some feed back from the setup.
They gave me the belt and pulley part number, along with the bolt size and banjo fitting size. I'm talking to another member about buying just the pulley section off his AMS kit so I can see if a spacer is required or not. He should be getting with me tmw and I'll update. I'll also have to talk to Andrew@AMS if it's ok to release the info for what's in the kit and the instructions. If not, I'll make my own instructions, lol.
Haven't heard back from him yet. I really just need the spacer as I have all the other parts lined up. I wonder if someone could post a good enough picture for me to send to a machine shop to have one made. Still on the hunt.
Well apparently we can take the PS off completely, loop the lines, and just use a smaller belt! Emery does it on the Ricer, so I believe that'll be my solution. Now to find the right length belt!
