AN hose for Mechanical Oil Pressure Gauge
Old Jul 31, 2014 | 07:25 AM
t3am 83rd's Avatar
anyone whose hooked up a mechanical oil pressure gauge inside of their evo 8/9, what was the length of the hose you used? What fittings did you use? I am going with a -3AN line with fittings, and I want to make sure I order the correct length and fittings. I've gathered that I'd need to order this ( http://store.42draftdesigns.com/Lanc...ptor_p_54.html ) to screw onto the the existing port on the car, and I already have an autometer mech oil gauge. I need all the fittings and the line. Any help would be appreciated. Thanks
Old Jul 31, 2014 | 05:34 PM
evojon's Avatar
AN line for oil pressure gauge
This may not be exactly what you're looking for because as I understand you, the line must go all the way from the filter housing to the location where you mount your gauge. I am going to order this for my gauge but it is electronic from sensor to gauge. However, AMS has been around for awhile and can make you exactly what you need and give you insight as to how long of a line they will need to make for you.
http://www.amsperformance.com/cart/A...Unit-Line.html
They helped me gather the parts I needed for my turbo kit and where always good to speak with.
Good luck,
John
Old Jul 31, 2014 | 08:15 PM
t3am 83rd's Avatar
Thanks, that is similar to what I need.
EvoIX89
17
Sep 22, 2015 07:11 AM
rn520
Mar 26, 2015 04:57 PM
Inprogress
May 15, 2014 06:43 AM
sabastian458
25
May 8, 2013 12:49 PM
trinydex
Mar 29, 2007 05:38 PM
