Help with cam install pointers!!!
Old Apr 8, 2004 | 11:02 AM
mikesevo8's Avatar
Originally posted by bishiboy
The front balance shaft IS driven by the main timing belt, which is also the oil pump. The rear balance shaft is on a different belt.
Yea, turboDan and I got it straight at Pruven.
Regardless, if you keep tension on the belt, it wont jump a tooth on either the crank, balance shaft, oil pump gears.
Old Apr 9, 2004 | 09:49 AM
weightless's Avatar
Originally posted by mikesevo8
I turned the engine by using the exhaust cam gear bolt (senses many people cringing)...
yup I def cringed when I read that. Another ghetto way to turn the engine is to put the car in 5th gear and push the car. That's a trick I did on my integra when doing valve adjustments, cams/cam gears install. It was much easier than jacking up the car and getting to the crank bolt. I didn't do the cams myself on my Evo tho, didn't want to risk screwing it up on a 30k car that's practically brand new.
Old Jan 27, 2008 | 04:21 AM
joedr's Avatar
EvoM Moderator
First time for me was around 3 hours on a IX cams. The IX intake cam can add another 30 minutes while figuring things up on the install of the intake side.
It is an VIII, so make sure that you replace all gaskets to prevent leaks! Torque to specs is crucial!
Old Jan 27, 2008 | 11:10 AM
bboy_RES's Avatar
first time installing my cams took me a couple days. i wasn't working straight through though. i had to go to work and i also had to drive to autozone because i needed a socket. i think if i worked straight through it probably would've taken me around 6 hours. the hardest part for me was undoing the exhaust cam gear bolt. that thing is on there tight!
Old Jul 15, 2010 | 12:55 PM
chinezboi4lyf's Avatar
hey! im installing hks 272's on my evo 9.
and i will be installing 1 hks cam gear, cuz i know that it only work with one on the mivec turbo (evo 9).
any advice? i wont be using a tensioner tool :/ cuz i wanna advance the timing on the gear.
and since im installing only 1 cam gear...which one is the one i have to replace? is it the exhaust gear or the intake gear? cuz the gears look diferent o___O
reismj
Lancer Engine Tech
Apr 21, 2016 10:20 PM
Recks_EVOX
Oct 13, 2015 09:42 AM
msemaniuk
Sep 10, 2014 05:41 PM
5280xEvo8
Apr 3, 2014 09:43 PM
MR. EVO MR
Aug 3, 2010 03:16 AM
