Wiring diagram for Lancer and EVO VIII
#34
I just put the backup camera in but I don't know where should I wire to with the black and red wires on the camera. I think it should be wire to reverse harness but I don't know which color cuz I found 1 jack beside the sub to the reverse light which's 2 red, 1 black, 1 yellow, 2 white...
#35
Thats easy if you have a volt meter or a test light. Put the car in reverse with the parking brake on and engine off to be safe. Check to see which wire has power. When you find one put the car in park and then see if you have no voltage. If no voltage then thats the wire. If not go to the next wire till you find it. Hope this helps
johnjonfenomeno
177
Aug 23, 2020 08:45 PM
tboboy
Aug 7, 2010 03:39 PM
