Best location for oil catch can
Originally posted by silverEVO8
Thanks, that's really helpful. BTW, I really like that upper IC pipe, where did you get it? Also, what is that BOV?
Thanks,
Thanks,
Keith
Correct me if I'm wrong, but is'nt the can just a glorified crankcase breather? By mounting it higher, don't you keep more oil in the motor where it's supposed to be? Should oil that is blown by be expelled? Just curious.
Cheers,
Cheers,
Cheers,
Cheers,
When I first switched over to the Buschuar intake I used a crank case breather filter and it pretty much put an oil film on my hood, firewall, strut tower brace, and transmission. That is why I chose to go with a catch can, my engine bay was filthy from the oil film.
Keith
Originally posted by nastea1
i have mine about level, and i still get oil in it...
anyway fourdoor, where is your MAF? are you running standalone?
My MAF is sitting behind me right now as I type this I have the AEM EMS stand alone and have converted to speed density.
Later,
Keith
Did a search to revive this thread looking for info on the GReddy catch can I bought.
I took the can to my engine to see where it ought to go.
This is where I'm planning to mount it. Unless anyone with a 4G94 found an easier better location.
Former Vendor
wow big pic... 1. the oil that we get in the intake or catch can is more of a thick vapor than just oil.. 2. if you look in my red pics link youll see i mounted mine under the air cleaner, and these is a couple of bolts down there already so you wont have to drill..
Fstyles05EB
Jan 31, 2017 04:39 AM
Imhere4you2NV
Jan 3, 2011 04:02 PM
